Bike won't start
ReggieGasket
Bike won't start
#1 Post by ReggieGasket » Wed Mar 19, 2014 7:51 am
I can't get the bike to start. She started first click at the end of winter. The battery is fully charged, but now she won't start. I wonder if the bike is flooded and needs time to clear, but I've been trying once a week. I have had a similar problem before when I miss the first catch, but the bike would start if I switched the "choke" off and gave full throttle. That technique isn't working. I'd guess something was wrong but the bike did catch for 5 seconds the other day. I hear lots of popping in the cylinders when the bike is turning over.
Anyone got another technique or do I need to clean the plugs? I'm assuming bumping is out of the question??
#2 Post by DavShill » Wed Mar 19, 2014 8:06 am
Hi Giles, just the usual technique which you seem to have tried. Other than cleaning the plugs etc I can only suggest a new battery. I had a starting problem back end of last year even though the battery was fully charged and had regular Optimate attention. I bought a new Motorbat and she burst into life.
If you want me to bob round I can bring my battery and see if she fires up.
Just give me a call.
jonnie_r
#3 Post by jonnie_r » Wed Mar 19, 2014 8:53 am
When were the plugs last changed? Mine starts getting funny about starting if the plugs aren't in good order.
Are you sure it's definitely just fuel coming out? I had a similar experience with water in the tank(albeit quite a lot in mine, about a litre), which combined with the plugs made it a right git to start.
#4 Post by randomsquid » Wed Mar 19, 2014 6:06 pm
How old is the fuel? The stuff round here doesn't seem to last long, especially from the little garage on the corner. I had a weird misfire on my kwak that was cured by using a different petrol station and the kwak isn't fussy by any means.
You could try shoving a can of fresh in and giving it a swoosh round.
ReggieGasket
#5 Post by ReggieGasket » Wed Mar 19, 2014 6:26 pm
Thanks guys, some good theories to test there. The plugs are probably a few years old now and the bike has been stood outside again in some heavy rain.
Thanks for the kind offer Dave, will text you :smt002
#6 Post by fatboy » Wed Mar 19, 2014 7:47 pm
Check the water drain in the filler cap (obvious amount of water if its blocked )
Then check the fast idle cable adjustment, the cable stretches and if its not adjusted prperly it wont open the butterflies enough for cold starting.
Then vacuum hoses ect
NickyT
#7 Post by NickyT » Sun Mar 23, 2014 3:04 pm
When mine won't start it's always because I've let the battery go a bit flat so it floods before it can fire.
The following method always works:
Remove seat
Connect battery to car via jump leads
Lift tank
Remove airbox lid if you have one (I don't)
Open throttle and spray a load of Easy Start down the intakes
Follow normal starting procedure
I usually get one big bang that ignites all the Easy Start but doesn't start the engine, then squirt in a load more, then try again. Works every time.
This bike is more prone to flooding than any I've ever owned.
GregD-UK
Flooding
#8 Post by GregD-UK » Sun Mar 23, 2014 8:10 pm
Don't forget too git big cylinders with loads of fuel can cause flooding or sometimes if left outside condensation in there too-boot :smt018
try a blanmet then a electric blanket and a bike cover ontop, keep her warm... Just like a woman :smt002
ReggieGasket
#9 Post by ReggieGasket » Mon Mar 31, 2014 3:39 pm
Yes, I've read a woman must have warm feet before any sort of hanky lanky can take place :smt007
#10 Post by Aladinsaneuk » Mon Mar 31, 2014 5:38 pm
Squid says the same about hooves - it's why he wears thermal lined wellies
