Front paddock stand
Posted: Thu Dec 19, 2013 4:17 pm
by stumblebum76
Hi all, can anybody please recommend a good front paddock stand for the Falco? I've done a ebay search for falco front paddock stand which throws up a few but I don't honestly know if they are any good! Any help muchly appreciated.
Posted: Thu Dec 19, 2013 5:10 pm
by DavShill
Hi mate - I use one like this. Takes a little care the first couple of times you use it before having confidence. It's not the most secure but it does the job for routine wheel and brake maintenance.
http://www.ebay.co.uk/itm/Warrior-Front ... 0652457070
Posted: Thu Dec 19, 2013 5:43 pm
i use one that fits into the under part of the headstock
its a faff to under the three bolts holding the cover on, but it is secure enough to do major work
Posted: Thu Dec 19, 2013 7:23 pm
I really do not trust front stands that lift on the fork bottoms.
Go for a headstock lifting stand, few more bucks but far more stable and you can work on the forks if needed, which you cant with a cheepie job
Posted: Thu Dec 19, 2013 7:31 pm
by stumblebum76
It's the headstock lifting ones I've been looking at, so any make of this style stand will fit? Any recommendations?
Posted: Thu Dec 19, 2013 9:13 pm
by paddyz1
Get an abba stand and the new front wheel lifter kit. You wont be disappointed.
Look on their website at the videos.
Posted: Fri Dec 20, 2013 5:42 am
paddyz1 wrote:Get an abba stand and the new front wheel lifter kit. You wont be disappointed.
Nooj was selling them? :smt017
Posted: Fri Dec 20, 2013 10:03 am
Nooj was selling clones of the abba stand - don't know if he still is or whether his ones work with the front lifting kit
Posted: Fri Dec 20, 2013 10:15 am
by wayno
Get one of the old NWS stands, they come up on ebay from time to time for about £50, same as the abba stand but universal and you don't need to pay for extra pins. Solid as a rock, you can then strap down the front or rear depending on which way you're working
Here's a pic of one http://www.bikechatforums.com/viewtopic.php?t=260045
Posted: Fri Dec 20, 2013 2:35 pm
wayno wrote:Get one of the old NWS stands, they come up on ebay from time to time for about £50, same as the abba stand but universal and you don't need to pay for extra pins. Solid as a rock, you can then strap down the front or rear depending on which way you're working
I've got one of them - certainly more robust than the abba but doesn't have some of the useful abba accessories - though I'd not swap it for an abba
Posted: Fri Dec 20, 2013 6:06 pm
by paddyz1
Tapered pins......Good idea...I am going to get the 695 pins machined down as they are long and will do the job nicely
