EFI
GregD-UK
EFI
#1 Post by GregD-UK » Thu Dec 05, 2013 5:38 pm
Well, twas my birffday yesterday! So, I decided to spend the day putting my Cat C back together somewhat. Fitted new radiator (Delkevic) OK, not quite same as OEM, but will do. Until I went to fit the rad covers :smt013 Fan mounting fixing points 5mm lower....
Anywho, fitted new stuff except plastics and main light. Soon as I put clocks back on, made a funny noise. Went to start it, no fuel as expected, so did the dreaded full throttle trick. Soon as fired went onto fast idle.... Champion me thought.
Till I looked at dash. EFI flashing continuously, no sign of temp on right hand screen. Turned her off and then back on and fired ok. Battery 14.2V :smt002 Anyone got any idea's on why my EFI is flashing continuously, even though she fired and was idling OK?
Cheers in advance, put my Aprilia SL Carbon Cans back on as well.
zoidberg
#2 Post by zoidberg » Thu Dec 05, 2013 6:21 pm
side stand switch?
#3 Post by Aladinsaneuk » Thu Dec 05, 2013 6:31 pm
Air sensor, right hand inlet
Either disconnected or damp
#4 Post by Aladinsaneuk » Thu Dec 05, 2013 6:32 pm
(There are a couple of other causes - do an Andy here for more
#5 Post by MartDude » Thu Dec 05, 2013 8:40 pm
Aladinsaneuk wrote: do an Andy here for more
What - go grey thinking about it?
GregD-UK
EFI
#6 Post by GregD-UK » Thu Dec 05, 2013 8:47 pm
Hi all.
Woops! Cheers Alad. The air sensor is off and disconnected. Will check in the morning :smt004 Side stand ok Zoid, light comes on and off and fires up....
#7 Post by D-Rider » Fri Dec 06, 2013 8:20 am
I believe we have something of a pot-kettle combo going on here .......
Falco668
#8 Post by Falco668 » Fri Dec 06, 2013 9:57 am
As I am only bout 25 miles away, thought I heard the SL cans explode into life the other day, !!!!!! Hope the rest of the build goes well.
Old age pensioners, hah, should be shot at birth!!!.
05 Bronze 'n Black. Nice!
GregD-UK
#9 Post by GregD-UK » Fri Dec 06, 2013 5:59 pm
:smt020
#10 Post by Aladinsaneuk » Fri Dec 06, 2013 7:20 pm
I note no one asked what an Andy was....
#11 Post by HisNibbs » Fri Dec 06, 2013 11:14 pm
I did a search to find out...
#12 Post by MartDude » Fri Dec 06, 2013 11:53 pm
HisNibbs wrote:I did a search to find out...
:smt005
GregD-UK
EFI.
#13 Post by GregD-UK » Fri Dec 13, 2013 10:33 pm
Fitted inner snorkel and connected said Air Sensor. EFI disappeared after two flashes and now temp has returned :smt002
Cheers Alad :smt003 Just need to fit rest of plastics, acquire push-rod for my rear brembo. Then bike back to it's former glory :smt004 Have decided to leave the SL Carbon Cans on for now, the TwoBrothers are fab and loud, might get some link pipes made and sight them in same place as carbons for the original "Twin" look :smt007
#14 Post by D-Rider » Fri Dec 13, 2013 10:35 pm
Glad it's all coming back together Greg :smt004
GregD-UK
#15 Post by GregD-UK » Fri Dec 13, 2013 10:54 pm
Cheers DR, you haven't rang me about the apprenticeship....
Have a restful w/end.
