aprilia front wheel
robbier6
aprilia front wheel
#1 Post by robbier6 » Fri Oct 04, 2013 7:48 am
Does anybody have a front wheel for sale, it appears mine has a crack as i have a slowly deflating front tyre, again, last one did the same so i can't be that unlucky to get two punctures in two tyres.
will also try and see where it's cracked tomorrow, using the old soapy water trick :smt002
zoidberg
#2 Post by zoidberg » Fri Oct 04, 2013 9:10 am
get in touch with a local fab shop and see if they can do a penetrant check. This will look for any surface flaw defects.
robbier6
#3 Post by robbier6 » Fri Oct 04, 2013 11:01 am
Problem is finding an engineering shop, plus the dye can be expensive then the x-ray to show up the dye, should get similar results using a soapy solution :smt003
zoidberg
#4 Post by zoidberg » Fri Oct 04, 2013 11:07 am
ya don't need to xray for a dye penetrant check. An xray will show up a crack too but will be more expensive.
a dye pen check should be too expensive certainly no more than an hours labour.
robbier6
#5 Post by robbier6 » Fri Oct 04, 2013 11:31 am
Cheers Zoid, i'll have a look round
zoidberg
#6 Post by zoidberg » Fri Oct 04, 2013 11:50 am
if you were closer i would have done it for you.
try soapy water first, see how you go...
#7 Post by flatlander » Fri Oct 04, 2013 12:32 pm
If none of that works I will have a set if wheels ready before Xmas :smt002
anarchicsaltire
#8 Post by anarchicsaltire » Fri Oct 04, 2013 12:53 pm
Always check the valve and around it first!
anarchicsaltire
#9 Post by anarchicsaltire » Fri Oct 04, 2013 12:53 pm
robbier6
#10 Post by robbier6 » Fri Oct 04, 2013 12:57 pm
Thanks Flatlander.....i may just find a huge pothole and have a claim of the LA, i mean it was after all an OZ rim :smt002
Saltire....i'll do that first, thanks for the heads up
#11 Post by blinkey501 » Fri Oct 04, 2013 9:25 pm
Got one here Robbie. :smt002 Pm me?
#12 Post by randomsquid » Sat Oct 05, 2013 7:18 pm
robbier6 wrote:Problem is finding an engineering shop, plus the dye can be expensive then the x-ray to show up the dye, should get similar results using a soapy solution :smt003
Wheel off and stick it in the washing up bowl. Move the wet bit round occasionally. Congratulations, you are now a certified air under water pressure test operative.
X-raying a bike wheel would be a pain in the arse to do properly and need multiple shots or a real time set up. Not the best method for cracks either because they tend to disappear if you hit them at the wrong angle.
If you get it dye penned try to get it done by someone set up to do fluorescent. Much more sensitive.
zoidberg
#13 Post by zoidberg » Sat Oct 05, 2013 7:49 pm
You in NDT squid?
#14 Post by flatlander » Sat Oct 05, 2013 10:54 pm
zoidberg wrote:You into sheep squid?
There fixed that for you :smt002
#15 Post by randomsquid » Sun Oct 06, 2013 1:38 pm
zoidberg wrote:You in NDT squid?
Was. Twenty years behind the set man and boy. :smt001
I keep getting bored and going and doing something else for a bit.
Did a job for my old lot round Christmas, probably go back at some point but I'm really enjoying myself not NDTing at the minute.
