The magpie
Posted: Mon Aug 26, 2013 7:08 am
The bike has now covered 46,000 miles and feels amazing apart from one niggle.
The bike vibrates through the handle bars from the engine.
I did mention it over the weekend to the ridersite massive at tunstall and a few idea's came to light.
Martdude did say that maybe the TB's could do with setting up.
The bike when cruising seems a lot better.
Whilst giving the bike the beans it seems hesitant until "it clears" then its business as usual. But even more vibey?
Marts idea does make sense, and since I have done the mid section mod I have not messed with the trim pots.
What is the standard setting for the trim pots folks?
The bike I think is on a standard chip and starts up with no issues at all.
I am thinking of going back to basics and starting from fresh.
I did consider that the mid section may not be right and putting the standard collector and standard cans to see if this improves things?
I need answers folks as I will end up with a bad bout of vibration white finger at this rate. :smt017
Cheers in advance folks
Posted: Mon Aug 26, 2013 8:59 am
As per our call
Check the vacuum hoses especially around the scottoiler....
Posted: Mon Aug 26, 2013 11:46 am
by zoidberg
I had a vacuum hose that was open to the air from a removed Scott oiler when I got mine. Ran heaps better once I removed it and capped off properly.
Posted: Mon Aug 26, 2013 2:16 pm
by flatlander
trim pots vary but with aftermarket chips I think the standard is 12 o'clock then start mving out from there
Posted: Mon Aug 26, 2013 3:24 pm
The air box clear oil collector tube was missing so another fitted.
Breather pipe from engine had come off but bike was still not right.
I bit the bullet and changed the TB's and all is well now.
The throttle was stiff so I have changed the cables and cable arrangement for another and that has improved things.
Time for a beer :smt003
Posted: Mon Aug 26, 2013 3:33 pm
Wouldve been just as easy to PX it in on a 'Busa..
Posted: Mon Aug 26, 2013 3:38 pm
Trim pots should be adjusted by measuring the CO ..... Which you probably don't have the kit for. Most seem to work from 12 o clock so that would be the place to set them if you can't adjust them. I expect Mart was suggesting you balance the TBs. You do this by adjusting the air bypass screws on the TBs to equalise the vacuum (measured with a carbtune manometer set or vacuum gauges) The workshop manual tells you what to do.
Posted: Mon Aug 26, 2013 4:06 pm
I believe I have the evoluzzione kit for that ;)
Posted: Mon Aug 26, 2013 4:07 pm
Fook it..... A trip to Griffs me thinks
