After lubing up the chain today, cleaning the excess off the sprocket carrier I noticed 4 of the 5 nuts were loose....
Is this the cause of my harsh vibey transmision feeling Ive had for 2 months now?
Everything on the clutch side is good
Rear sprocket nuts
Rear sprocket nuts
- Falcopops
This happened to me (one of the studs snapped too) the movement ovaled out the holes in the carrier and buggered the bearing. Be worth pulling it off to check it.
While your at it check the bolts that holds the cush drive casting to the wheel too. There have been known to have worked loose too, but rarely.
