Finally got to try out the MWR HE induction kit last Sunday & have found it very impressive. This was surprising, given already have a Power Commander III fitted with a custom map to go with Beowulf cans. The PCIII smoothed out a flat spot around 5,000 rpm, removed majority of the snatchiness low down in the rev range & now have a linear power delivery right throughput the rev range. This combo improved output from 118 bhp at the crank to 115 bhp at the wheel. This was done directly after a service by Griff. (Also have a 15/42 sprocket setup). There have been no other engine mods & 12,000 miles on the clock.
The MWR HE kit gave the Falco even smoother progression from closed throttle/low revs & appears to pile on the revs quicker too. When overtaking, I found that I could leave the bike in a taller gear (e.g. 4th rather than 3rd) & she pulled slightly stronger than before. It certainly seems to 'breath' better & the alleged technology of creating an even air pressure around the entire rim of the induction area seems to work & work well. It looks the d.b. too when you lift the petrol tank.
When I get the Falco serviced with Griff next time I will have a new custom map made, as recommended by MWR, & update this thread if anyone shows an interest.
Would I buy this piece of kit again - absolutely! as it seems to address the issue of the air box volume being too small & would probably have more of an impact to a Falco that does not have a PCIII &/or custom map. It looks a quality piece of kit & is just so easy to fit. Bought mine from the friendly people at speedycom.co.uk (Part # MC010-97-HE) in Derby & got a small discount off the £159.99 RRP.
Hope this helps if you are struggling to find an alternative to a renegade, or renegade copy induction kit & personally think this looks a lot better.
