Mixed up wheel spacers
Posted: Wed Jun 26, 2013 11:01 pm
by Falco Frank
Apologies as I've had a few drinks after emerging from the garage.
I've had both wheels out to get them painted and the rims polished, which took longer than I expected and then I found the rear linkage needle bearings were shot & had to replace them as well.
The upshot being it was a while since I remembered the wheel spacer order!
I reassembled the rear wheel with new sprocket and for some reason had a shiney, nickel plated looking spacer that I got it into my head fitted between the bearing in the outer hub & the cush drive houseing / wheel..
But when I installed the wheel I pushed it right forward to fit a new chain and the cush pin bolt heads were catching on the weld at the very rear of the swing arm, where I guess the wheel adjuster assembly is welded on.
Worse still the rear wheel diagram on the SL Mille 2001-2005 pdf (from the Martin site) is different to the one on the Aprilia Yorkshire (parts manual pdf) !
I'm confused and goign to bed but any illumination is very welcome.
Posted: Thu Jun 27, 2013 12:35 am
I reckon you're spot on with the location of the spacer, No.24 in the pic.
The issue with the cush pins hitting the swingarm has raised its ugly head a couple of times recently which seems to be due to the new sprockets being thinner than they need to be. IIRC the solution is to put some washers on the cush pins behind the sprocket, this will push the pins further into their sockets and reduce the amount of bolt protruding beyond the sprocket carrier.
Hopefully others will confirm this, worth having a search while your hangover is clearing and measure the relative thicknesses of the sprockets to confirm.
Posted: Thu Jun 27, 2013 10:05 pm
by Falco Frank
Many thanks Falcopops, i ended up pulling the wheel out again and checking and found some crud between the no24 spacer and the sprocket carrier.
Made little difference because when i progressed to fitting my new chain, with the 44T sprocket ive fitted i ended up needing it half way along the available adjustment and well away from the weld.
I dont think using spacers will work anyways sadly, as the hex flanged part of the cush bolts are hard up against the cush drives, so spacers would only move the sprocket carrier outwards?
Out of interest i measured the sprocket thickness' on the carrier and my new one was 2mm thinner, alloy Tallon, than the steel Afam, which was 8mm thick.
Cheers, Frank
Posted: Thu Jun 27, 2013 10:32 pm
by Falco Frank
Quite happy with todays work....
Here's a 'teaser' photo :smt001
Posted: Thu Jun 27, 2013 11:46 pm
iconic944ss wrote:Made little difference because when i progressed to fitting my new chain, with the 44T sprocket ive fitted i ended up needing it half way along the available adjustment and well away from the weld.
That's the same sprocket as I have on mine I think, good that it clears.
iconic944ss wrote:I dont think using spacers will work anyways sadly, as the hex flanged part of the cush bolts are hard up against the cush drives, so spacers would only move the sprocket carrier outwards?
That's point, the swingarm bears against the outer spacer in the sprocket hub, so if the hub is further out and there is less of the cush stud threads sticking through because of the washers the clearance will be improved.
iconic944ss wrote:Out of interest i measured the sprocket thickness' on the carrier and my new one was 2mm thinner, alloy Tallon, than the steel Afam, which was 8mm thick.
Good work, it's useful to know what thicknesses are out there so we know what may cause problems.
Posted: Fri Jun 28, 2013 9:01 am
by Falco Frank
I understand now, Thanks for the information.
Front end next :smt017
Posted: Fri Jun 28, 2013 1:55 pm
There's only one spacer in the front, goes on the side where the axle nut goes, whichever side you decide that is going to be
Posted: Fri Jun 28, 2013 3:21 pm
by joecrx
iconic944ss wrote:Quite happy with todays work....
i might be wrong but you will have to turn your sprocket round so the taper is on the inside keeping the line for the front sprocket , going by the pic
Posted: Fri Jun 28, 2013 5:48 pm
by Falco Frank
I wondered about that too, no manufacturer markings (Talon etc) on the inner side, only the side I have facing outwards...
