water in petrol?
Posted: Sun Jun 23, 2013 6:57 am
Starting to get a worrying fault - occasionally the falco coughs and surges as if going onto reserve, random sorts of times, either under load or on a steady throttle on the motorway. Thought it might be water or dirt in the petrol, but that's a couple of tankfuls now and still there.
If it had carbs I'd whip the float bowls off, or even just undo a drain plug - any advice on simple things to try? Assuming it's as straight-forward as just dirty fuel.....
Other than that, all well in falco-land, slightly dodgy indicator flasher unit aside.....btw, didn't mention that I finally fitted the correct and expensive new battery and started first prod - after 5 months sitting in the garage - very impressive!
