Charging modification completed.
Posted: Sun Feb 24, 2013 9:33 pm
This is my simplified version of the charging mod.....
^ Testing it out before getting the soldering iron out.
^ This is where the 4 pin white connector was. 2 red positive wires into 1. 2 green negative wires into one. Soldered straight off the regulator rectifier.
^ This is simply the two wires being connected to the positive and negative of the battery. I used a ring crimp then soldered it.
^ New battery voltage at the display.
^ New battery voltage measured using a decent meter rather than anything electric made by italians.
The display is half a volt out.
Charging mod complete. Simple.
