May be of interest re bars
#1 Post by Aladinsaneuk » Sun Feb 10, 2013 1:10 pm
I recently acquired a set of Gilles Vario bars - no longer made so getting a tad rare
This morning I started to fit them, but I also compared them re position of the bar
Obviously, the vario bars have a lot of adjustment - BUT they would, for my desired setting, be pretty much the same as fitting the bars over the triple
So, I am not going to fit them - for others who are taller/shorter or need more adjustment, then they are ideal, but for those of us with a 5 '9" Buddha physique, bars over the triple is as good
slickliner6
Re: May be of interest re bars
#2 Post by slickliner6 » Sun Feb 10, 2013 5:31 pm
Aladinsaneuk wrote: 5 '9" Buddha physique
aaahhhh i resemble that remark. :smt003
we were so poor when i was growing up.Dad said "its a good job i was born a boy,at least id have something to play with" ;-)
#3 Post by HowardQ » Sun Feb 10, 2013 5:49 pm
I was going to ask how much different they were from the normal bars over the yokes.
I now have an answer, so I may eventually go down the "over the bars" road, as I have the same outstanding 5 '9" Buddha physique.
P.S. Nearly forgot, the other thing is does it make it any easier without modding the fairing?
With the bars over the yokes you can get away with an bit of juggling around of the brake cylinder etc., and may even manage it on standard brake lines etc., if you loosen the nearest ties to the bars.
#4 Post by Aladinsaneuk » Sun Feb 10, 2013 6:10 pm
Only thing, at least on my falco, that I had to do was to remove the bat that holds the brake reservoir and rotate my switch gear a tad
No fairing fouling at all
wayno
#5 Post by wayno » Sun Feb 10, 2013 7:46 pm
Mate of mine spent 150 quid on a set of fully adjustable bars for his rsv, we now constantly take the piss out of him as they're in the same position as the stock ones he took off :smt003
#6 Post by randomsquid » Sun Feb 10, 2013 8:48 pm
Aladinsaneuk wrote:remove the bat that holds the brake reservoir
They're a protected species you know. Why not just use a metal bracket like a normal people?
Now, how do I get bars that are in the standard position but wider?
#7 Post by Aladinsaneuk » Sun Feb 10, 2013 9:04 pm
You get longer clip ons, or vario bars - they adjust in all planes....
wayno
#8 Post by wayno » Mon Feb 11, 2013 10:14 am
randomsquid wrote:Now, how do I get bars that are in the standard position but wider?
If you lost some weight they might seem wider?? Or superglue some spacers to the side of your hand so you can't get your hands as close together?? Just a few low cost solutions :)
Seriously though, if you got some clip ons with removeable handlebars then there's no reason you couldn't swap these with any length of bar, thus giving you the perfect length.
#9 Post by D-Rider » Mon Feb 11, 2013 10:35 am
wayno wrote: Seriously though, if you got some clip ons with removeable handlebars then there's no reason you couldn't swap these with any length of bar, thus giving you the perfect length.
Visions of randomsquid trundling along the road with a big pair of wings sticking out the sides of his Falco (sponsored by Red Bull* of course)
*Other energy drinks are available
#10 Post by randomsquid » Mon Feb 11, 2013 6:37 pm
I'm big boned...
I find I'm riding with the heel of my hand on the anti cyclist knobs on the end of the bars. I've looked at clip ons but then I'd lose the rise on the standard bars. Maybe clip ons over the yoke. Still pondering this one.
#11 Post by Aladinsaneuk » Mon Feb 11, 2013 6:43 pm
Moving the bars over the triple will not make them longer
I do know of a set of vario bars with brand new tuono throttle cables that would be wider if adjusted that are for sale...
Love
CMOT Dean
#12 Post by fatboy » Mon Feb 11, 2013 7:34 pm
Were these for sale recently ?
Any pics ?
I find std Falco bars put a lot of pressure on the temple area of right thumb
ReggieGasket
#13 Post by ReggieGasket » Mon Feb 11, 2013 8:03 pm
I've put the standard clippons over the yokes, but I'd still like them higher and further back. Wouldn't adjustable clippons go higher than standard if fitted over the yokes?
ReggieGasket
#14 Post by ReggieGasket » Mon Feb 11, 2013 8:06 pm
Another idea. There must be standard clippons from another bike which fit the forks and are higher and further back?
#15 Post by D-Rider » Mon Feb 11, 2013 8:12 pm
Ah the Falco chopper club is back discussing their ape-hangers again ............
:smt009
