Oil everywhere !!!!
Posted: Fri Apr 13, 2007 10:31 am
by DazBIke
On the way in to work this morning about 2 mile out of Frome, come up to
a roundabout, i start banging down the gears and my foot kept slipping
off the gear leaver. I look down to see my left leg and left side of the
bike including the rear wheel, covered in engine oil !!!! Oh chap!!
I let it cool down then limped home. it didnt aprear to be leaking too
much by the time i got home.
I think that it might have been over filled at the last service the other week. Gave
then a call today and they seem quite happy to have a look at it. Bit
pissed off, but what can you do! :(
Anyone know of anything else it could be other than being over filled?
Anything i need to check?
thanks.
Posted: Fri Apr 13, 2007 10:46 am
by danowat
Left hand side?, drain plug and oil filter housing is that side.
I would be suprised if it was because of overfilling though
Posted: Fri Apr 13, 2007 10:53 am
by DazBIke
danowat wrote:Left hand side?, drain plug and oil filter housing is that side.
Yeah left hand side.
I'll have a better look when i get home, but it looked like it was coming out of a
number of places which makes me think the oil pressure has built up to the piont
it leaks.
Posted: Fri Apr 13, 2007 11:31 am
by scottyni
had similar last friday. looked down and it was all over my boot. the oil filler plug wasn't put in right by dealer!!!
all okay now so i hope it was just that for you Daz.
Posted: Fri Apr 13, 2007 11:34 am
by DazBIke
scottyni wrote:had similar last friday. looked down and it was all over my boot. the oil filler plug wasn't put in right by dealer!!!
I hope so m8. Ive done 200 mile from the service so would have thought if it
was that, it might have made its self know sooner.
I just hope its not feeked! :(
Posted: Fri Apr 13, 2007 1:06 pm
by Falcoholic
Yup I had this too a couple of weeks ago after MOT.
It was the hose on the top of the oil cooler on the front of the bike. It had sprung the "safety" clip and spewed all the oil out onto the road, my boots trousers and bike. I replaced the clip with a jubilee and filled it back up with oil. No problems since but it might be worth a look see just to make sure it ain't that.
Posted: Fri Apr 13, 2007 5:03 pm
by TimB
Check the rubber oil hose that runs to the oil tank near the oil filter.
Item No 14 on this pic
http://www.apriliayorkshire.co.uk/catal ... Oil%20tank
Mine got a split in it a few weeks ago and spewed oil all over the back tyre and underside of the bike.
Posted: Fri Apr 13, 2007 5:14 pm
If the breather hose that plugs into the airbox bets blocked that will also cause oil to spew out everywhere.
Posted: Fri Apr 13, 2007 9:11 pm
by Thumper
It sounds like the feed from the oil tank into the engine, in fact this was the subject of the one and only recall by aprillia on the falco if it's not split check out the clips.
Read this;
http://www.geocities.com/sl_mille/recall.html
Posted: Mon Apr 16, 2007 8:32 am
by DazBIke
thanks for all your posts, I will be checking all the options.
I didnt get time this weekend to have a good look as i was at
Thruxton all weekend. However i did notice the the thread on the
oil filler cap has gone! Now my question is; would this be the problem
or an effect of the problem if you know what i mean?
thanks for all you help chaps ;)
Posted: Tue Apr 17, 2007 11:17 am
by Thumper
Yes the oil could be coming from a loose filler cap but that would be easy to spot.
