Headers - will these fit a Falco
mickt1964
#1 Post by mickt1964 » Sun Sep 09, 2012 6:54 pm
Kept an eye on these on ebay
http://www.ebay.co.uk/itm/261090283507? ... 500wt_1182
Sellers says they were on a Falco and were on when he bought the bike. As far as he knows rest of the bike was standard falco, as I asked him if the oil and radiator mod had been done, he didn't know or realise.
With the kink at the far end in the picture, I am thinking they won't fit straight on, which is what I was hoping for.
Mick
Re: Headers - will these fit a Falco
#2 Post by blinkey501 » Sun Sep 09, 2012 7:14 pm
mickt1964 wrote:Kept an eye on these on ebay
Mick
If you look at his other items you will see he is breaking a falco so the answer to you question is yes...
The guy prowls some other aprilia forum's and his forum name is nob, he is known on here too :smt002
mickt1964
#3 Post by mickt1964 » Sun Sep 09, 2012 7:43 pm
Hi Blinkey
Thanks for the info - wouldn't the bike have needed the mods doing for these to fit or have the mid pipe been altered?
Mick
#4 Post by blinkey501 » Sun Sep 09, 2012 8:08 pm
mickt1964 wrote:Hi Blinkey
Mick
You have two choices you can fit a mille oil tank but if you have a belly pan you will have to cut it slightly to accomadate the tank... I have an oil tank for sale if you want to go down this route.
To save all this hassle you can ask Greg D to see if he can sort you out a mid section.
You will have to supply greg with the correct mid section has there is two mille types.... Try the search function for other information there is loads on there, but to set you on your way.....
Here you go to see what you will get for your money
https://www.ridersite.com/viewtopic.ph ... id+section
