It was going so well....
Posted: Thu Sep 06, 2012 6:36 pm
The battle to get the falco done is in its final stages,despite a wasted day yesterday because my paddock stand didnt arrive ( 24 hr express delivery means when I can be bothered to Pacelfarce drivers), got a lot done today, tyres fitted for £20, would have been £10 if the boss wasnt in,
old blue spring shock out, dropped white spring unit in, went to start bolting it up and..................... :smt010
the valve will not clear the subframe, its fouling by 1 to 2 mm,
Think Im going to carefully grind it
Posted: Thu Sep 06, 2012 6:44 pm
erm
you have searched about fitting a white spring shock here haven't you.....
i think that in the vast majority of cases, people have to dremel off 1 to 2 mm - and yes use a dremel not a grinder
you will also find that the cover won't fit on either..... but once the above is done its well covered....
(And i am sorry - i did think you knew this already....)
Posted: Thu Sep 06, 2012 7:50 pm
Must admit to being a minimum effort searcher,therefore didnt read everything I should have read, being dyslexsic helps too, being an impatient twat helps even more :smt012
Have to put my hand up and say I didnt know cos i didnt read it
Posted: Thu Sep 06, 2012 8:54 pm
no worries
pm one of us if you need to call to answer questions
Posted: Thu Sep 06, 2012 9:57 pm
by flatlander
And they'll just ignore you ;)
Posted: Thu Sep 06, 2012 10:21 pm
we just recognise your number Geoff
its on so many toilet walls - even in Russia iirc.....
