That big bushy bit on the top yolk - torque setting
#1 Post by randomsquid » Mon Sep 03, 2012 5:43 pm
The one with the 14mm hole in.
Manual says 80 Nm, which I did.
Bars still seems to turn freely but it seemed like a lot of tightening before the torque spanner went click.
Any thoughts?
Re: That big bushy bit on the top yolk - torque setting
#2 Post by D-Rider » Mon Sep 03, 2012 5:50 pm
randomsquid wrote:The one with the 14mm hole in.
Any thoughts?
Yes - it is very tight.
It won't affect the stiffness of the steering, the loading on the bearings is sorted out by the rings below the thing you can see - and they have a tightening sequence that requires torquing to one value, slackening off and then re-torquing to another.
#3 Post by randomsquid » Mon Sep 03, 2012 6:49 pm
Cheers, that's put my mind at rest.
I suppose very tight is better than able to unscrew by hand. :smt108
