Falco doesn't give me the horn anymore
Posted: Thu Apr 12, 2007 8:06 pm
I press the horn button and it blows the fuse, which means I also loose the dash, headlight, tail and brake lights and indicators.
Everything else works together and in isolation, and with as much stuff as I can turn off turned off, pressing the horn button still blows the fuse.
So... switch, wiring or horn? Where do I start my search for the short? Any ideas?
Re: Falco doesn't give me the horn anymore
Posted: Thu Apr 12, 2007 8:31 pm
by sabestian
Nooj wrote:I press the horn button and it blows the fuse, which means I also loose the dash, headlight, tail and brake lights and indicators.
I'd start with a switch. It is really poor quality. I don't think a horn can cause a short? I may be wrong. Hate electrical problems
Posted: Thu Apr 12, 2007 9:30 pm
by paddyz1
Pull the grey wire off the horn and then try it. If the fuse blows strip the switch for a short.
It is most likely the grey is shorting out somewhere.
FYI, the green wire is the power to the switch. (The green powers the high/low/pass and horn)
Posted: Fri Apr 13, 2007 5:15 pm
That's one of tomorrow's jobs then, thanks for the tips.
Posted: Fri Apr 13, 2007 9:19 pm
Almost certainly the horn itself or. possibly, a short to ground (frame etc) from the wire between switch and horn.
Switch itself is highly unlikely.
Not looked at the wiring diagram to confirm but I think I'm probably confirming what Paddy already said.
Posted: Sat Apr 14, 2007 8:24 am
by Gtrain
Don't know how to fix your problem, but would like to fit a proper (read loud and manly) horn to the falco, getting sick of that little sound the original makes, so has anyone fitted a proper horn to your bird?
