Ddogy adjustements on white RSV shock?
Posted: Fri Aug 10, 2012 2:40 pm
by SimonDk
[Repost as I fear it's missed in the suspension sticky thread]:
Have acquired a 2nd hand white spring unit, had it refurbed at a local mx shop, and:
Have discovered that the top compression knob will do only 35 clicks (not 45 like manual states), while bottom rebound screw will do 45 clicks (manual states 25) .. ? What's up with that; cause for concern?
Posted: Fri Aug 10, 2012 5:13 pm
Doubt it tbh
If it works, then it is good
Also - maybe shock is upgraded version . Or manual is wrong ;)
Posted: Fri Aug 10, 2012 8:27 pm
by back_marker
I think mine may do the same. Also, if you look at the standard compression setting according to the manual it suggests that it should be wound pretty much all the way out
