Swingarm Bearing Removal
Need to replace the needle roller bearing on my RSV swingarm.
Anyone have any tips on how to get it out, the lip for the o ring prevents knocking it out from the other side.
Why do I need to replace it? I have had the arm polishing and I protected these bearings with a threaded bar and large washers covering the holes.
I think the polishers took this off, why, as it was obvious what it was for.
So both bearings were full of polishing compound and the bearing sounds likes its running in sand. Tried washing out with parafin.
The other side was so bad the bearings wouldn't move. These have been replaced.
Mick
Mick
I haven't yet found anyone who has removed them and not had to do this - at least on one side. It's certainly what I did and always suggest to those that ask.blinkey501 wrote:I do believe willapotus used a dremel to remove them
- anzacinexile
- Willopotomas
Here's the large tap ....Willopotomas wrote:Not quite. I used a large tap and a slide hammer. Getting them back in is a lot easier.. (obviously new ones)blinkey501 wrote:I do believe willapotus used a dremel to remove them
.... and here's the slide he knocked together with his hammer ..........
- GregD-UK
Bearing Removal...
I used an 1/2 inch long extension bar and a plastic hammer
Put through the centre of bearing one side and hit with said hammer on the inner other side, simples. Took my time though, watch out for the spacer and position everytime to minimise the damage on the spacer....
Re: Bearing Removal...
I tried that .... and gave up as I couldn't get the thing to stay on the bearing well enough to knock it out.GregD-UK wrote:Hi all,
I used an 1/2 inch long extension bar and a plastic hammerPut through the centre of bearing one side and hit with said hammer on the inner other side, simples. Took my time though, watch out for the spacer and position everytime to minimise the damage on the spacer....
Good to hear you managed it.
- GregD-UK
Patience...
Remember DR, patience is a virtue, wanted by all and held by few
I decided to dig up this old thread, as I've had cause to remove the bearings from my standard Falco swingarm, as I'm intending to get it powder coated black to match the frame.
Piece of piss - took about 20 minutes, tops. And no Dremels were involved, and all bearings can and will be re-used. Crucially, no swearing was involved either. Dunno what all the fuss is about, honestly...
- anzacinexile
Indeed - other than when located in the general area of Sheffield, their bearings seem to drop out easily.anzacinexile wrote:Yes..............mickt1964 wrote:Hi Mango
The original question was for the RSV swingarm and not the falco, are they the same internally?
