Certainly is good advice.
It made some difference to mine when the master had been round it.
Yeah you don't want to play with the trim pots without a CO meter .... I'm still looking for one at the right price ....rick wrote:I agree re: taking it to Griff, and have already provisionally booked a suspension setup session in the new year... but I would also like to know how to set this up (albeit without expensive equipment such as CO meters).
I expect it will work fine.rick wrote: I do have a home-made manometer using ATF and a piece of 2x4 and metres of rubber tuning... worked well on my IL4 so thought I'd use it on the Falco...
errr isn't the clutch on the RHS ??rick wrote:
...although it appears the best advice is to use the two vacuum ports on the RHS of the TBs and not the smaller tubes on the clutch side... the problem is I can only see one vacuum port on the RHS that is used for the clutch.
Yeah sorry, I meant the clutch slave cylinder side is the LHSD-Rider wrote:errr isn't the clutch on the RHS ??rick wrote:
D-Rider wrote:Also, as you have one of the early Falcos, you may have a set of the early throttle bodies.
In the picture below the early ones are shown on the left and the later ones on the right.
The early ones are missing a vacuum port and you need special adapters that fit underneath the throttle bodies to balance the TBs with vacuum gauges or a manometer.
Take a look in the workshop manual - the adapters and how to use them is shown in there
I've looked in to this .... the old set pictured is a set I picked up from ebay - not realising they were the old style.Falcopops wrote:Why oh why would Aprilia have omitted the vacuum point on the early models!
If you have to take them off then it should be simple enough to drill and tap in the blank for a spigot to emulate the later models, just a thought.
