New Falco owner in person
- randomsquid
- Wear the Fox Hat
They're fair on price and they've seen falcos before.spiderwheels wrote:OK thanks. that doesn't seem so pricey :) I'll give them a ring!blinkey501 wrote:
I got quoted 170 quid for progressive springs. Oil and seals. I thought that was fair.I think that included postage back to me also. Not sure though
I'm assuming you have marzocchi forks, if so there's a manual here. http://www.martinpoll.dk/div_april.htm
I just took mine to Revs, he's local to me. Made a big difference to the handling. He had to strip the forks and measure the springs before he ordered the new ones, think he was used to Falcos with showas on.
It was a couple of years ago but I think he charged me £370. That was for taking the forks and shock out. Rebuild, respring and revalve the shock. Rebuild and respring the forks and put the bike back together. I know a goodly chunk of the cost was parts. I remember him saying one of the mudguard bolts was more or less stuck, rather it was his problem than mine.
Don't know if its been mentioned but according to the forks download from that link, the oil weight for marzocchi is 7.5...
Pg 84 section 6.2
Pg 84 section 6.2
Marco Simoncelli.
Marco Simoncelli.
I took my Ohlins forks to Revs to be serviced before I fitted them in place of my Marzocchis.
I was happy with what he did - and John's a great guy too.
No idea regarding improvement though as I've never had a set serviced for the Falco that I've previously used.
I think it's about time I had my ohlins rear shock serviced .... but the thought of having to go back to using the blue spring sachs while it's away is not an appealing prospect.
- randomsquid
- Wear the Fox Hat
It wouldn't take long to turn round during the off season. Mine was done in two days, would have been one if he'd had the springs in hand.D-Rider wrote: I think it's about time I had my ohlins rear shock serviced .... but the thought of having to go back to using the blue spring sachs while it's away is not an appealing prospect.
Randomsquid makes a good point - it certainly looks like your Falco has the less common Marzocchi forks. The internal design of those is quite different to the Showa equivalents, but as RS says, Revs have seen them before. The progressive springs that Revs will fit will almost certainly be Wilbers rather than Hyperpro, but there's nothing wrong with that. Wilbers make good quality kit.
Nitron shocks have a good reputation, so don't be put off it. Does yours have a ride height adjuster on it (normally situated below the rebound adjuster)? If not, then you might want to scour eBay for a suitable Ohlins or Sachs RSV shock and sell yours on using the Bay of e... Setting rear ride height is key in getting the bike to turn properly, and if you don't have that adjustment it's a bit limiting.
If it does, then your quids in, of course.
What is this "off season" of which you speak? Is there a specific time of year in which you are meant to fall off then?randomsquid wrote:It wouldn't take long to turn round during the off season. Mine was done in two days, would have been one if he'd had the springs in hand.D-Rider wrote: I think it's about time I had my ohlins rear shock serviced .... but the thought of having to go back to using the blue spring sachs while it's away is not an appealing prospect.
Just a matter of finding time to get the shocks and linkages swapped over then riding to the other side of that blot on the landscape of Birmingham (never a quick or pleasurable experience), leave it to be sorted, find time to go and collect it (across Birmingham) and then re-fit it.
Not going to be that quick and take a couple of consecutive free Saturdays to drop off and collect .... there's another challenge.
I'll get it done sometime.
Well yes & no and noAladinsaneuk wrote:Yep
Fitted as standard to later slower colours
Some of the earlier bikes of the later colour schemes got showas - though most got marzocchis.
The colours might be slower but that's just the handicap system to compensate for them being ridden by the faster riders (with Keith being the exception - of course)
..... be able to get one retro fitted if you contact nitron (or a suspension specialist - maybe even Revs)mangocrazy wrote:
Nitron shocks have a good reputation, so don't be put off it. Does yours have a ride height adjuster on it (normally situated below the rebound adjuster)? If not, then you might .....
Worth asking anyway.
The later bikes could come with either Showa or Marzocchis. It's my suspicion that the Marzocchi-clad bikes were the real last of the line models, as Aprilia had run out of Showas and had to source an equivalent to get the last bikes out the door. But that's purely a guess on my part.spiderwheels wrote:I thought all forks on these were Showa. I've not seen anything before about Marzocchi in everything I've read so far! :) Was this a change to the later bikes like mine?
Take a photograph of the fork caps/tops and we can positively identify one way or t'other.
Mine's a Flamingo Red/Anthracite model with the black frame and mine has Showas. But looking at the engine/frame number it seems to have been made early in the late model production run (if you know what I mean) and has Showas fitted.
Same with Futurasmangocrazy wrote:]
Not entirely sure I'm on solid ground here but didn't the Tuonos of those years also have showas?mangocrazy wrote:It's my suspicion that the Marzocchi-clad bikes were the real last of the line models, as Aprilia had run out of Showas and had to source an equivalent to get the last bikes out the door. But that's purely a guess on my part.
