Got myself a new Italian bird...
just to add
i like and rate the condo road attacks on the falco - good mileage and good grip in the wet and dry
BUT
please do research tyre pressures here - do not - as a general rule, go for the official aprilia recommended pressures... - 36/42 is a generally accepted starting point for many - some run on less than that.....
oh - the 520 option is not often done
BUT
What, a bogey contest?Jadaris wrote:Welcome aboard the green crew![]()
I'm another Oasis Green owner, hopefully see you at some of the meets so we can get the greenies lined up together
The Oasis Greens - The Bogey Bikes!
Similar discussion a while back on a Futura forum - consensus was that 520 probably isn't a good idea - won't last.Aladinsaneuk wrote:Hmmmm
I think even the Mille owners only go for 520 on track bikes
Not sure if I am correct but the torque the rotax puts out may eat the 520 bits....
If you need to lose some weight, a good dump usually works for me
- flatlander
I loved the old R1 advert of the bike outside a burger bar with a sign saying full English brekkie and the tag line
We shaved another 4kg off the bike .... What for ?
People go 520 on the ZX9R and that makes quite a bit more power and torque than the Falco. A quality 520 chain is going to be better than a middle of the road 530 chain.MartDude wrote:
Anyway, it's moot as I don't need a chain or sprockets.
Though whats this about dropping to a 15t front? I'll be doing longer distance rides, and usually people go the other way for touring.
As I said in my text
Ride it for a while and see... Some people find the 15 helps while commuting in town - personally I did not do it... But I have a Ducati sport so I learnt to slip the clutch like a pro!
Going to a 15-t front definitely made the Futura easier in town traffic. And, perhaps slightly bizarrely, it improved the fuel consumption slightly - I'd guess through being able to get into a higher gear sooner, and hold a higher gear for longer. I know the Fut is quite different to the Falco (heavier, less power, bit more torque, engine's set up differently - softer cams, different ECU, different fuelling etc etc) but it's still a big grunty V2, so my comments should be applicable to a degree.
I still think, and this applies to any and all who are new to the falco fold, put a few hundred miles on the bike the see what needs adjusting or changing
For me the ONLY exception to that is the sidestand... Change it straight away!
wayofthedarkhand wrote: What do i need to fit it? I imagine that being European, the bolts are all different and my toolset is geared towards Japanese bikes
Yes.. when you rap your knuckles when a spanner slips (shouldve used a ring spanner..) you have to swear in broken Italian not broken Japanese
Other than that, sizes shouldnt be much different.. 10mm is 10mm is 10mm.. etc
If this were a BSA Bantam, I'd say otherwise..
Ok. I thought it might all be torx, or hex or something like that.
