Honda stand
Falconihlist
#31 Post by Falconihlist » Sat Sep 03, 2011 7:28 pm
I used the blade spring and had no problem fitting it with a spring puller. The spring is slightly longer, but fits and works fine when connected to the Falco bracket.
Black is fastest!
#32 Post by mangocrazy » Sat Sep 03, 2011 10:17 pm
Falconihlist wrote:I used the blade spring and had no problem fitting it with a spring puller. The spring is slightly longer, but fits and works fine when connected to the Falco bracket.
Using the correct tool? That's cheating... :smt003
kaisermuldoon
#33 Post by kaisermuldoon » Sun Sep 04, 2011 6:44 am
Looked in the toolbox but can't decide which one is the "Spring Puller" is that the Hammer or the Chisel? ':smt017'
#34 Post by D-Rider » Sun Sep 04, 2011 7:24 am
LOL.
Nothing like having a tool that'll pull springs easily - I struggled with this for years - improvising with screwdrivers and pliers etc.
..... then Aldi came to the rescue with this set of tools for a couple of quid (or so) - the tool at the top is perfect for doing springs.
Falconihlist
#35 Post by Falconihlist » Sun Sep 04, 2011 8:20 am
Might add, it was an exhaust spring puller :smt003
Black is fastest!
#36 Post by mangocrazy » Sun Sep 04, 2011 8:20 pm
I measured the (converted) GSXR stand on my Falco today, and it was pretty much exactly 250mm/25cm from pivot to heel of stand. So it seems like the Blade/GSXR stands are pretty much interchangeable in that respect. One thing I'd like to compare is the angle of dangle of both stands, as that could also make a difference.
Maybe I need to shell out for a Blade stand on eBay and do a proper comparison...
#37 Post by flatlander » Mon Sep 12, 2011 2:01 pm
http://www.wemoto.com/oem/
Part number search for P/N: 50530-MEL-000 is the 2004-2007 CBR1000RR sidestand
http://www.powersportsplus.com/parts/de ... 4Qodc3-p1A
Looks like there are two numbering systems running for some reason!?
Partno Make Description Price (Excl VAT) Qty.
50530MEL000 Honda Bar Comp Side Sta *g £ 63.80 £ 53.17
#38 Post by furygan man » Mon Jan 23, 2012 3:14 pm
Had the stand done on Friday and i must have got so used to the original/boobsywhasit that it really looked leant over, and the leg more forward. Griff assures it's right, just gotta get used to it i guess!!
kaisermuldoon
#39 Post by kaisermuldoon » Tue Jan 24, 2012 8:03 pm
furygan man wrote:Had the stand done on Friday and i must have got so used to the original/boobsywhasit that it really looked leant over, and the leg more forward. Griff assures it's right, just gotta get used to it i guess!!
Did you trim the length of the stand? I felt it was too upright initially and took about 15mm off. Never did receive the Bubseywoo stand, did get a refund though. Did you fit the Honda switch as well, if so does it kill the engine properly when the stand is flicked up?
old git
#40 Post by old git » Wed Jul 04, 2012 6:14 am
Just incase someone searches in the future, I have also fitted a Hayabusa stand to the Falco to good effect.
About 2 inches longer than standard so stand holds further out.
Use existing bracket & switch.
Bolt needs fitting in the oposite direction & blob of weld on the top, but overall quite easy & a good mod.
[img]C:\Users\keithm.OPELLALTD\Desktop\Temp Folder\Hayabusa - falco sidestand.jpg[/img]
[/img]
Sleepyboy
#41 Post by Sleepyboy » Fri Jul 06, 2012 5:44 pm
old git wrote:Just incase someone searches in the future, I have also fitted a Hayabusa stand to the Falco to good effect.
[/img]
Pic doesn't work - do you know which age of Busa fits?
#42 Post by Nooj » Fri Jul 06, 2012 9:36 pm
old git wrote: [img]C:\Users\keithm.OPELLALTD\Desktop\Temp Folder\Hayabusa - falco sidestand.jpg[/img]
[/img]
You can't link to things on your hard drive dude, you need to host it on line somewhere :smt003
