MOT and 1st ride out
- flatlander
...F9 has suggested a new, meatier battery like the ytx14bs thing I eventually fitted to the blue one. Having bought it only a week ago and doing no less than 7-10 miles everyday between starts - could it really be that simple? I rode 7 miles to the gym, it sat for 2 hrs outside, then I rode 12(ish) miles to the supermarket - with a 20min stop there.
At least 10. But that's without any of the lights turned on.
You're going to need to ride it for longer/further between stops mate. Otherwise you're going to have to change the battery every few months at best.
Your other alternative is to hook it up to a battery optimiser every time you park up.
- flatlander
I refer to my earlier comment
and IIRC you have to do over 4000 revs for it to have charging benefit
...the charging stuff is really surprising, but good to know. Forgive my ignorance, but how is it that modern cars with all their electrical dependencies, seem to start regardless of distance? Bigger engines? More heavy-duty charging components? I didn't realise this. I use the bike for everything, notably work - will be a push to quadruple my commuting distance, but if needs must, I'll try. Will also try the solar charger route since the bike will invariably get laid-up for a week or two - depending on snow & ice in London.
Food for thought.
Food for thought.
- flatlander
manual says up to 17 days in "normal temp" without charging is ok but ...
and Rob
and Rob
Listens no pays attention maybe acts on any advice I give without getting better opinions first almost deifinitelyFalcorob wrote:
Yeah but anyone that listens to you is certifiable mate.
Complete bolloxAladinsaneuk wrote:iirc
need to do 20 miles at least to replace the battery cost of starting....
(sorry Pete)
I have a 7 mile daily commute (3.5 miles each way). It only goes on the optimate if I'm going away for some time and won't be riding it for a while.
BTW Kerry - If it's showing the Diag 1, you must have the diagnostic connectors joined together ..... any particular reason for this?
It's normal to have these disconnected unless specifically investigating diagnostic codes.
Andy - your commuting distance follow up blows my easy fix idea. FYI if you read this thread back Rich says he's 'separated' the diag wires. Would them being connected impact on it starting? God, now what? The straight-to-zap start really worries me - even with the other one, on its rubbish rob-hunter battery gave me more feedback when cold or low. Will ask rich about whether he's changed/ungraded the starter solenoid.
quite probably is andy - but I think that it is a useful rule of thumb - and I am will too bet that you warm your engine up etc before riding and then ensure the bike is put away properly - not quite tucked up with a blanket but....
I know that I can leave mine for a long time with out using the optimate, but if i have been using the bike for short blasts then I have learned the hard way to put it on charge.....
I know have a spare door stop in my garage..... though it was an old spare battery!
- flatlander
Bearing in mind my earlier disclaimer
If it tries to turn over can't recall if it does, but on short journeys could it cause it to run weak by not getting hot enough to burn the fuel edge ir fly and leaving a watery mixture for next start?
Certainly not a bad thing to doAladinsaneuk wrote:quite probably is andy - but I think that it is a useful rule of thumb
Nope - turn it on and off I go .... no time for pissing about - I'm always running late.Aladinsaneuk wrote: I am will too bet that you warm your engine up etc before riding
It does get stuck away in the garage - but its a detached concrete garage and not very warm - just keeps the wind and rain off.Aladinsaneuk wrote:then ensure the bike is put away properly - not quite tucked up with a blanket but....
