Coolant
#31 Post by fatboy » Sun Nov 17, 2013 6:45 pm
System open to allow burpage to escape,try rapid repeated squeezing,
Tonyunn
#32 Post by Tonyunn » Sun Nov 24, 2013 1:08 pm
Another three hours and I seem to have sorted it, got it to run at 75 and 74 degrees which it has not done but then I realised I never ride at this time of year and it had no plastic on it, anyhoo put all of the bits back on and a run up to 90 mph for a longer run and it settled at 76 degrees on the nose.
I think it is just dumb luck and plenty of "burping" that fixed it in the end.
Cheers for all of the help from the gallery.
She is now under blankets on an opitmate and looking forward to the spring.
Speed Blue SL 1000 Falco
mrapriliafalco
#33 Post by mrapriliafalco » Fri May 01, 2015 10:55 am
Im Gonna Change the coolant on mine this year,do you need around 4 litres
#34 Post by D-Rider » Fri May 01, 2015 11:16 am
Service light came up on mine last week ..... Oil, Filter, Coolant etc all purchased (the liquid items from Opie using our forum discount) so will be changing all of them next week.
Glad it's not a valve check service this time.
Yes burpage is going to be in order ..... often a bit hit and miss - the link hose between the rads being a good air-lock location.
Tonyunn
#35 Post by Tonyunn » Fri May 01, 2015 12:58 pm
After all the crap I had the first time, last week I had cause to take out some coolant after I had then put it back ran the bike for 15 minutes and then cracked the pressure cap, let it settle and then checked the level, seemed to sort itself straight away this time.
mrapriliafalco
#36 Post by mrapriliafalco » Fri May 01, 2015 1:41 pm
nothings ever simple is it !!!!!!!
Did u need 4 litres mate
Tonyunn
#37 Post by Tonyunn » Fri May 01, 2015 2:13 pm
Can't honestly remember, I bought to of the correct bottle and use one and a half of them, still have some as spare, did the 50\50 mix.
mrapriliafalco
#38 Post by mrapriliafalco » Fri May 01, 2015 2:42 pm
presume you mean 2!!!!What product did you buy??
#39 Post by MartDude » Fri May 01, 2015 4:07 pm
I'm so glad I have an air-cooled bike :smt019
(And what a shame there isn't a smug bastard emoticon)
#40 Post by D-Rider » Fri May 01, 2015 9:19 pm
mrapriliafalco wrote:nothings ever simple is it !!!!!!!
It's something like that. I checked in the workshop manual before I ordered mine but can't remember now for sure .... a quick look at the workshop manual will tell you.
