todays top tip
Don't ride over to Leicester with your son for his Part 1 motorcycle test on 5th December.
When you get there you will find it has been cancelled as it was "too icy"
You will also find they rang his mobile to tell him this - but only when we were already halfway there and, of course, didn't notice the call as we were riding.
Great advice that .............
- randomsquid
- Wear the Fox Hat
- flatlander
When you smell burning plastic in the car then yes the fuses have blown again
If you are soldering wires, do not grab hold of the wires you have just soldered. They will be hot.
The same applies for items of steel that you have welded together, especially if they have only just stopped glowing.
And on the theme ...... (going back a few years here) .....
When you are short of soldering irons at work and you and a colleague need to use one at the same time, don't assume that just because you are right handed and he is left handed that you can both share the same iron in complete safety.
After a while, without looking at what you are doing, you will both go to pick up the iron at the same time. You will get there first and start to pick it up and he will grasp where the handle was only a split second before ..... and firmly grasp the hot tip ....
- randomsquid
- Wear the Fox Hat
My family have had a learning week...
Don't pour caustic soda down your front unless you want to be pink, puffy and hairless.
And from my sister. Make sure there are no cats in the washer before you turn it on. Unless you want a really pissed off (but very soft and fluffy) cat.
- randomsquid
- Wear the Fox Hat
