You'd be very hard pressed to find an alternative rear wheel to fit the Futura hub/axle assembly; AFAIK it's unique.Falconihlist wrote:If said Futura arm becomes available at the right price, I could be tempted, but with a different set of wheels too. I reckon I would probably have to go onto a Mille exhaust as well.
The OEM king bearing - a large double-race bearing in the hub - is bloody expensive (but there are plans afoot to source a cheaper alternative); one of the races has magnets embedded in it for the speedo sensor.
Dismantling of the hub/king bearing assembly often results in FUBARing the king bearing, and can also knacker the stub axle; if the bearing has been neglected, it can snatch on the axle, necessitating serious work on the axle - e.g. flame spraying and re-machining.
Oh, and you can't remove/replace the caliper hanger without dismantling the hub/axle assembly.
Still interested? I've got a spare swinging arm, and hub, and axle. But it would take a very good offer to persuade me to part with them
