Quick release seat pins
- furygan man
Any chance of titanium ones???
sticking throttle
sorry, another question, apologies for posting 2 in the same day.
My throttle would appear to be sticking. Twist and it will hold at the same speed as opposed to decelerate in true Vtwin fashion.
I noticed that when i used my heated grips the throttle became a bit more sticky and I had assumed it was the heat on the rubber but not the heated grips (Oxford) no longer work and the throttle has become stiff and sticky - dont know if they are related.
any ideas?
bit of WD liberally placed anywhere?
Dave
any ideas?
Dave
undo the bar end - then try it
if it then works as it should, then trim the end of the grip with a stanley knife - carefully..... like 1mm
i had to do that with my oxford grips
if that is not it, post again
- Willopotomas
It's a pain in the arse. And an expensive one at that.. Unless you're willing to spend lots on tooling (carbide tips.. lots of um) then I wouldn't bother. Most titanium parts cost so much because they're a bugger to make..lol..wayno wrote:Not sure, I've never machined titanium before so I don't know what it's like, except expensiveNooj wrote:Any chance of titanium ones???
Anyway.. Why bother.. The weight saving for parts so small is going to be hardly noticeable..
Bling factor
- Willopotomas
Lol, there's not telling some people.Willopotomas wrote:Thought the point of 'bling' was that people could see it..
I have carbide tips at home so I could give it a go, not gonna though. (unless my mate buys some titanium for the weight saving he's doing to his bike). The question I wonder is what's it like for threading with a die?
Anyway, I'll keep you all informed on the progress of these. Should be simple enough though
- Willopotomas
Single point screw cutting is better.. Difficult with a die as it has the tendency to smear or stick to the tool.. Carbide thread cutting tip on the lathe will do a better job.. Don't be afraid to take loads off in one pass either.. Taking off tiny amounts isn't advisable. A cut of less than 0.15mm will cause problems with heat build up. Titanium isn't a very good heat conductor, so all the machining heat tends to stay on the cut face and the cutting tool.. Look to take off between 0.25mm and 0.50mm per pass..wayno wrote:The question I wonder is what's it like for threading with a die?
Oh. and run it slowwwwwwwww
Ok, I have ordered all the parts I need and will starting knocking up some sets when the bits arrive anyone who definitely wants some give me a shout, either PM or in this thread.
The only question I would ask is would you prefer nylon or stainless washers, I ordered stainless and then realised nylon may be better for the tank ones.
I can do them for £8 a set delivered in the UK mainland, anyone outside the UK wanting some will have to give me a shout to get postage (or more likely source them locally).
