Mirror vibration/looseness
#16 Post by Falcopops » Sun May 30, 2010 10:12 pm
rick wrote:Cheers for the tips guys, I'll try and take the glass off and stick it back on - regarding soaking it in petrol, with this degrade/fade/damage the plastic at all?
Cheers.
does no harm at all to the plastic body.
There's a double sided sticky foam pad holding the mirror on that the petrol softens to get the glass off. The plastic under the miror is held in by a couple of screws, these may be the problem, so whip them out and check them and the moulding they fasten to.
The sticky pad should still be quite sticky (depending on how long its been in the petrol) and could be reused once the petrol has evaporated. Prolly need a bit of extra glue to make sure it stays put.
#17 Post by D-Rider » Sun May 30, 2010 10:31 pm
D-Rider wrote:My Falco is Bronze
My tash is not a stand-alone item .... it is accompanied by a beardy-type thing
What is a PO56 ?
Kwackerz wrote:Partial numberplate i think, although it could be some special secret code for 'YFFF'
Well if that's what it is, then someone must have taken mine and re-registered it - not a PO and mine's about 18 months older.
rick
#18 Post by rick » Mon May 31, 2010 6:32 pm
It was indeed part of the number plate, but I only caught a glimpse as they rode off...
