Ignition/Immobiliser problem = dead bike
- Firestarter
- Twisted Firestarter
I must be lucky, have said it before but I've never had a problem with my Datatool S3.
One thing I've noticed, had the key in (so the alarm was disarmed), had accidentally knocked the killswitch while doing somethin, and the alarm started to arm. sounds like you may have something similar, maybe a broken wire somewhere on the same circuit as the killswitch?
- Firestarter
Yeah the alarm 'appears' to be working normally in that sense - tilt/tamper sensor is working. Enables, disables. But... it's not recognising the ignition coming on, ie it auto alarms itself after 30 seconds despite the ignition being on.
I spoke to Datatool today and I have to get a voltmeter across a couple of pins to see if there is a problem between the ignition and the pin on the alarm.
*sigh*
*sigh*
- Firestarter
well .... there are those on the left of the dash and there are a couple under the seat. I can't remember which ones are in which locations but I think the under seat are the main fuses - so don't think it will be them.hornetrider wrote:I've checked the ones to the right hand side of the dash which are ok - are there any more to check?
- Firestarter
