A nice run... and a few questions...
Syltiz
Chaos Merchant
#16 Post by Syltiz » Tue Mar 17, 2009 11:42 am
wavey wrote:Doesn't it say in the manual to remove the bung in the little tube after washing? Or is that a fuel tank issue? I recall doing so after the first couple of cleans, not bothered since.
Dave
:smt017 Im confused. Are you talking about the bung in the drain tube coming out of the RHS of the airbox? If so Im not sure how washing would have an impact... do you mean washing the airbox to clean the oil? Then I suppose yes cos you would want to drain the results of your washing. Ive probably got the wrong end of the stick completely so forgive me if this does not make sense.
wavey
#17 Post by wavey » Tue Mar 17, 2009 12:50 pm
You're confused, you want to try living in my head for 5 mins!
I think there is a little drain tube fitted to to fuel tank, it has a bung to be removed after washing to remove water from the tank. Not that any water gets to the fuel of course, but it must get somewhere.
Right, at work or not, i'm going for a lie down.
Dave
wavey
#18 Post by wavey » Tue Mar 17, 2009 1:10 pm
Ok, no 14 here http://www.ultimateparts.net/shop/categ ... 03-Air-box shows the tube Dyzio was talking about( I think)
Whereas if you look here http://www.ultimateparts.net/shop/categ ... -Fuel-tank you will plainly see that I am talking bollox
Now for that lie down
Dave
dyzio
#19 Post by dyzio » Tue Mar 17, 2009 1:21 pm
it was on the RHS so no 20 (I think)
wavey
#20 Post by wavey » Tue Mar 17, 2009 1:23 pm
14 is rhs as you sit on the bike
dyzio
#21 Post by dyzio » Tue Mar 17, 2009 1:24 pm
Syltiz
Chaos Merchant
#22 Post by Syltiz » Tue Mar 17, 2009 1:31 pm
Dave
Sorry - that should read LHS. No.... crap! Now you got me confused. Im going out to look at the bike! :smt001
Syltiz
Chaos Merchant
#23 Post by Syltiz » Tue Mar 17, 2009 1:39 pm
#20 is your breather tube from your crankcase (LHS as you sit on the bike). That should stay as is as you dont need to do anything with it. #14 is the drain pipe to collect oil that collects in the airbox from (RHS as you sit on the bike) which from time to time you should clear.
Now Wavey must still be in that beating-man-u-4-1 hangover cos I have no clue what pipe you are referring to there on Planet Wavey :smt002
wavey
#24 Post by wavey » Tue Mar 17, 2009 2:36 pm
TORRES!!! TORRES!!! TORRES!!! TORRES!!! TORRES!!! TORRES!!!
ibicker
#25 Post by ibicker » Tue Mar 17, 2009 5:49 pm
get a new battery. All the worlds problems will be solved!
dyzio
#26 Post by dyzio » Tue Mar 17, 2009 6:30 pm
ibicker wrote:get a new battery. All the worlds problems will be solved!
Wouldn't help (for long). The battery was replaced by the previous owner.
Did the wire mod, bike started fine today, will see how it goes.
