HT caps, suggestions please.
wayno
#16 Post by wayno » Fri Apr 12, 2013 8:42 am
Just to confirm, those magnecor leads are the complete lead and plug set, I just emailed them to clarify as the listing only says leads.
Here's the reply
"Hi Wayne, they are a direct replacement for the OEM ignition leads, no other item needed.
Best Regards
Dear race_spec_performance,
Hi,
Can you tell me if this item is just the lead, or does it come supplied with the required 'caps' on the ends. i.e. does it plug straight onto the coils and spark plugs or do I need to fit anthing else to this.
thanks
Wayne"
#17 Post by fatboy » Fri Apr 12, 2013 6:04 pm
D-Rider wrote:Not certain but I think Dale might have meant the OEM caps - rather than those Magnecor jobs
So Dalemac, is it the Magnecor caps that fall apart or OEM ?
Midnight Rider
#18 Post by Dalemac » Fri Apr 12, 2013 7:57 pm
fatboy wrote:So Dalemac, is it the Magnecor caps that fall apart or OEM ?
The OEM caps fall apart.
My theory is that if you push the caps on too hard, the metal retainer clip bends, meaning you cannot get them off without snapping the graphite in the caps.
old git
#19 Post by old git » Sat Apr 13, 2013 12:53 pm
wayno wrote:Just to confirm, those magnecor leads are the complete lead and plug set, I just emailed them to clarify as the listing only says leads.
Here's the reply
Best Regards
Hi,
thanks
Wayne"
Got the mags on mine last year, well pleased, I had the starter reckoned at the same time, really easy 1st time starter and no issues now.
