Oil for Falco
Falco Frank
#16 Post by Falco Frank » Wed Nov 28, 2012 10:49 am
Been a while since I posted here so a quick line on oil....
Just drained the oil on my SL in readiness for winter, quite surprised to learn there is a coarse metal filter to check inside the oil tank? Mine was clean as a whistle, manual says you need to remove the special banded clip on the oil line on the top of the oil tank.
Pull the hose off and then a socket is needed, 27mm I think as access is poor to remove a nut with long cage into the tank and the metal filter. You will need a jubilee clip, for 22mm bore pipe to complete the job.
As an aside, I thought I was running the same 10/40 oil as my Duke but my book says Full syn 15/50, so a quick look on Ebay shows Smith & Allen in Darlington selling Shell Helix at great prices (inc free delivery) that get MUCH better for buying in bulk....
I made a best offer of £80 on 4 x 4L bottles, with free delivery and they accepted! More still available here:
http://www.ebay.co.uk/itm/300638108798
Mines on its way, K+N oil filter ready to go in and then - job done.
Didnt realise there is an option of fitting a longer oil filter (good post/spot) even my Ducati oil filter is much larger than the Falco, having said all that I've had a good look in my old filter and its pretty clean really.
PS - Hiya, Paul - fancy seeing you here ;)
#17 Post by Aladinsaneuk » Wed Nov 28, 2012 1:09 pm
Many of us here use opie oils - we get a forum discount
Also, some of us use 10/40 semi .... Aprilia have said it is specifically for bikes that show signs of clutch slip but - its cheaper ;)
#18 Post by D-Rider » Wed Nov 28, 2012 1:24 pm
iconic944ss wrote:
As an aside, I thought I was running the same 10/40 oil as my Duke but my book says Full syn 15/50, )
15/50 Fully synth is fine for many of the later bikes but some of the early Falcos will not tolerate fully synth (clutch slip)
The 15/50 oils recommended in the Falco User Manual are actually Semi-synth not fully-synth
Falco Frank
#19 Post by Falco Frank » Wed Nov 28, 2012 1:52 pm
I thought that as well but looking at the Agip website, the recommended TEC 4T oil showed up as fully synthetic???
I guess I can always use the oil elsewhere but if I get slip the it might be a very expensive engine flush!!!
#20 Post by D-Rider » Wed Nov 28, 2012 3:41 pm
No it doesn't show as fully-synth.
It's either referred to as "synthetic-based" or "synthetic-fortified" - which translates to semi-synthetic.
That said, unless you have one of the older falcos, you should have no problem choosing to use fully-synth (I normally do). In fact, not all of the old ones object to it either.
Chabby
#21 Post by Chabby » Sun Dec 02, 2012 5:26 pm
A while ago I was reading about clutch failures on Falcos/Milles relating to the cush drive type coil springs on the rear of the clutch basket breaking up from the mounting plate and causing damage to the casings.
I noticed that all of the affected clutches were of a different type to mine (which is a black 2000).
I think it’s a logical conclusion that the earlier clutches were prone to slipping and were later redesigned (2001 on).
I would continue to use semi synth on the earlier clutches.
On the bright side – the earlier clutch appears not to spit out the spring retaining plate. As far as I can tell, the clutch assemblies are interchangeable
#22 Post by blinkey501 » Fri Dec 14, 2012 5:28 am
I am finishing a sprag clutch this weekend and i will be fitting a new filter and oil.
I have tried to find which oil filter fits that is a car one, i seem to remember a nissan micra filter fits but i can't find the year or engine size in the search function.
Does any one know which fits, this is the long filter! :smt002
#23 Post by Aladinsaneuk » Fri Dec 14, 2012 6:05 am
call griff - he has them in stock
oh - I think it is an HF564 but could be wrong - the shorter one is HF152 iirc
#24 Post by D-Rider » Fri Dec 14, 2012 10:02 am
blinkey501 wrote:I am finishing a sprag clutch this weekend and i will be fitting a new filter and oil.
Why not just fit the proper one rather than one from a car?
:smt017
#25 Post by blinkey501 » Fri Dec 14, 2012 8:11 pm
The reason i am thinking about one from a car is i can pick one up over the wekend and not wait for postage....Thanks chaps anyway :smt002
Or is this a sign of defeat and the great oracles don't know :smt017 :smt104
#26 Post by Aladinsaneuk » Fri Dec 14, 2012 11:12 pm
actually, i did post but wifi at work blocked the reply
you need a HF152/564
