engine change
engine change
after being let down by two mechanics i am now left with a bike which i need to change the engine myself are there any pitfalls to watch out for during engine swap ?
- anzacinexile
As Anzac said - get the workshop manual and read the relevant parts. Then read them again.
If you get to a point where you're uncertain as to what to do, STOP! Have a look at the manual, have a look at where you are, and take it little step by little step.
If you're still uncertain, ask the experts here.
Use labelled zip-lock bags to keep all your nuts and bolts in. (Eg: "clutch cover bolts", "fairing screws", etc, etc.) This will stop you losing things.
Have a good supply of rags / degreaser / WD40 on hand. You'll need them at some stage.
Above all, take your time and don't rush things.
- Willopotomas
- GP Racer
As everyone else has said RTFM
Dont use excessivice force unless the good book says so
Photos, labels, seperate labelled bags brill idea
Try and put engine mounting bolts in the location they came from,may save confusion later
If it gets too much STOP and put the kettle on
Its only Meccano on a bigger scale and this is a fkin brilliant site so if you need to shout HELP your call will be heard by many
PS If you need to mark something in its position BEFORE it is removed ( mark on frame/ mark on bolt that holds it ) use Tippex or yuor Mrs nail varnish
- blinkey501
- blinkey501
Try arran auto centre in dundee, young pete does the bikes there good job at a fair price.willmoir wrote:ok cheers having studied the manual and taken onboard the advice given i think i should be ok hopefully get bike home at wkend
i live near edzell in angus scotland approx 400 mile from coventry but thanks anyway Willopotomas
Cheers Keith
We did one at trackside in.. minutes.
Isnt hard.
RTFM. Twice.
Oh and dont drop the engine. It's heavy and you have to wiggle it about.
Watch the header bolts dont shear off.
rear header bolts are a twat to get to.
cant remember much else other than that.
Isnt hard.
RTFM. Twice.
