Sprocket carrier bolts
Moose
#16 Post by Moose » Tue Apr 19, 2011 2:24 pm
I'd be tempted to cut the rubber down to fit.
I did consider this, but the rubber has a metal sleeve in it so I thought it would be easier to have the shoulders reduced.
#17 Post by Falcopops » Tue Apr 19, 2011 10:16 pm
I had my suspicions there was a sleeve in there, but couldn't see it on the parts diagram soz.
Moose
#18 Post by Moose » Fri Apr 22, 2011 1:27 pm
Picture!
As you can see the one on the left's shoulder is thinner than the 2nd from left, the other two are turned down.
I have fitted the third one to the bike and it fits perfect :smt003
#19 Post by Samray » Fri Apr 22, 2011 1:37 pm
:smt023
#20 Post by D-Rider » Fri Apr 22, 2011 4:48 pm
Moose wrote:Picture!
Well if you can't find a glass slipper, the perfect fit of the 3rd bolt is not a bad substitute.
Moosey - you shall go the the ball !
