Aprilionaire
- Despatch Rider
#1
Post
by Aprilionaire » Sun Jan 16, 2011 10:26 am
I have just aquired an Ohlins from a 2000 RSVR , do I need the dog bone and triangle plates from this model to make ot fit my Falco? Cheers geezers
BTW, It was the one on Ebay recently, I couldn't cope with being bounced around any longer
Alan
Has anyone seen the plot?
Falco9
#2
Post
by Falco9 » Sun Jan 16, 2011 11:11 am
Yes you do
F9
#3
Post
by D-Rider » Sun Jan 16, 2011 11:27 am
Yes you do but you have them already ..... as the 2000 model Mille/MilleR used the same dog bone and triangles as the Falco - so you probably don't need to buy any more!
Check the Ultimate Parts website:
http://www.ultimateparts.net/ and you'll see the part numbers are the same.
The only caution I'd add is are you sure it came from a 2000 model mille?
anzacinexile
#4
Post
by anzacinexile » Sun Jan 16, 2011 3:04 pm
I'm with D - that's my set-up with standard Falco dogbones
tommy
- Clubman Racer
#5
Post
by tommy » Sun Jan 16, 2011 5:54 pm
+1 Mine also came from a 2000 RSVR. Uses same dog bones etc. Should have a 140lb spring I believe
#6
Post
by mangocrazy » Sun Jan 16, 2011 6:11 pm
tommy wrote:+1 Mine also came from a 2000 RSVR. Uses same dog bones etc. Should have a 140lb spring I believe
It won't have a 140lb spring - it might have an Ohlins code printed on the spring that has '140' somewhere in it. Actual spring rate is somewhere around 800lb.
tommy
- Clubman Racer
#7
Post
by tommy » Sun Jan 16, 2011 6:56 pm
mangocrazy wrote:tommy wrote:+1 Mine also came from a 2000 RSVR. Uses same dog bones etc. Should have a 140lb spring I believe
Whoops, my bad. You're right. 14 Kgf/mm spring is 800 lb/in. Written as something like 54/140 on the spring (for 14 N/m spring)
Aprilionaire
- Despatch Rider
#8
Post
by Aprilionaire » Mon Jan 17, 2011 11:02 am
Nice one, I knew I'd need the dog and plates to fit it, just not sure if the RSV ones were needed/different.
Well no I'm not certain its off a 2000 model, but I just have to take my chance that they weren't tellin porkies, I'll get it to work, I'm an engineer
Just need some good mini indicators now as the ones I bought "Bike It" same as Oxford mini Spear, were a pile of shite and I sent them back!
Alan
#9
Post
by D-Rider » Mon Jan 17, 2011 11:58 am
Check the spring markings as posted above - that will confirm
Aprilionaire
- Despatch Rider
#10
Post
by Aprilionaire » Tue Jan 18, 2011 10:46 am
It has 1093-54/140 359 on it. Cheers.
Alan
#11
Post
by D-Rider » Tue Jan 18, 2011 7:55 pm
That sounds right from what Tommy was saying
