RSV injector bodies
wayno
RSV injector bodies
#1 Post by wayno » Wed Dec 22, 2010 9:51 am
Does anyone know how much these normally cost, and is it any of the ones off 98-04 RSV's that will fit and speed up the bird? Are these the elusive 54mm throttle bodies I've heard about (this is actually the first injected bike I've ever owned, I'm still old school carbs.
Falconihlist
#2 Post by Falconihlist » Wed Dec 22, 2010 10:04 am
I've got a throttle body, but I'm not sure what it's from. Bought it as I needed a spare injector at the time, but I think it was from an early Mille. Trying to work out what it is from using the part number on the side, but having no luck so far.
Black is fastest!
wayno
#3 Post by wayno » Wed Dec 22, 2010 10:11 am
I was just curious as I'd seen a set on e-bay from the same people I just got a RSV rear shock from.
Got plenty of jobs stacking up for the Falco now, new shock once I've had it serviced (can anyone recommend a good company), new sidestand (I've chanced it long enough with the old one), new set of machined levers, finishing up my adaptor blocks to fit RSV indicator mirros and make a new tail tidy to fit some smaller rear indicators.
Falconihlist
#4 Post by Falconihlist » Wed Dec 22, 2010 10:15 am
I'll keep looking, but no doubt someone will be along with the right information eventually to help out. I've thought about the indicator mirrors, but haven't been able to find any mounting blocks. Have you made them yourself?
Black is fastest!
wayno
#5 Post by wayno » Wed Dec 22, 2010 10:29 am
I'm going to make some blocks. I did think about buying a set fomr the guy on the american forum for $100 a set, but I think I'll just make my own.
Going for a slightly different design to his, he makes a block which goes under the complete indicator, I'm going to unscrew the bottom section and make a longer block, it should be a lot easier. I'll post some pics if I ever get round to them
#6 Post by Aladinsaneuk » Wed Dec 22, 2010 10:48 am
i think you will find that the later milles had 57mm throttle bodies and are not much use for the falco - would need different injectors or adapters or something else - and the actual performance gain is negligable compared to the 54 bodies
the 54mm throttle bodies are made by boring out the standard 51 bodies - and then machining a butterfly or something... oh, and then getting some new velocity stacks
i know that D=Rider cannot see this forum at his work place, but am certain he will be along later with the contact details of who can do the work
i also feel that to get the best from the 54 throttle bodies you will need a chip change, PC3, open airbox and decent exhausts
they do give the bike a hell of a lot of oomph though :)
wayno
#7 Post by wayno » Wed Dec 22, 2010 11:01 am
Oh ok, I didn't realise the 54mm ones were modified 51's, I thought they were just standard off one of the RSV's
#8 Post by Aladinsaneuk » Wed Dec 22, 2010 11:15 am
nod - many think that - the milles went from 51mm bodies on early models to 57mm on later ones
#9 Post by furygan man » Wed Dec 22, 2010 7:26 pm
! :smt001
#10 Post by D-Rider » Wed Dec 22, 2010 11:17 pm
Yes 54s are bored 51s - Aprilia never made such things.
Somewhere on here are details of a place that said they could convert them for you.
TBH I wouldn't bother as I contacted them and they were hopeless at communicating. Gave up in the end.
Bear in mind that you'll also need 54mm velocity stacks to go with them.
I have heard that 57s will work OK on the falco if set up right (and with the necessary connector mods) - though they give no performance benefit over the 54s on a Falco (due to limitations with the Falcos heads - valve sizes and cams) ..... though late model RSVR heads will fit .....
BTW I do have a couple of spare sets of 51mm TBs if anyone is interested.
#11 Post by mangocrazy » Wed Dec 22, 2010 11:29 pm
Did anyone ever manage to source the spigots to convert the early Mille/Falco TBs to later spec (i.e. with twin spigot?). I have a pair of 51mm TBs, but they're the early ones with one takeoff and one blanked off (undrilled).
#12 Post by D-Rider » Wed Dec 22, 2010 11:33 pm
No - but if you do, let me know as I've a set of the old style that could do with converting - as well as a set of the new style
