The purpose of the preload adjuster is to set your sag - so, yes, check your sag and if appropriate, adjust.hornetrider wrote:If there's little difference from stock then that suggests to me the preload is wound up and perhaps the compression/rebound are also too firm. Try winding the preload off a bit and ensuring the damping adjustment is in the middle of the range.
If I remember, when we had our settup with Griff, he was recommending for most people a rear sag of about 10mm (without rider) ...though not everyone was the same I think he was suggesting less to those people "of a larger frame" than those of a light build - which would make sense.
If anyone can confirm the sag that Griff was suggesting, then that would be helpful.
