rsv rearsets?
rsv rearsets?
anybody know if rsv rearsets fit the falco? cheers all.
The rearsets themselves fit, but as Andy says, the Falco brake and gear levers won't fit with them.
You can bolt the entire RSV/Tuono rear brake set up (master cylinder, lever, brake line, brackets and heat shield) onto a Falco if you extend the pipe from the master cylinder to the existing reservoire.
You can use the linkage-free RSV/Tuono gear lever, but you're Falco will have a GP shift pattern: 1 down, 5 up. The way around this is to take out the gearbox and turn (I think, the shifter star??) part of the mechanism round/upside down/inside out.
