GregD-UK
#1
Post
by GregD-UK » Tue Jun 30, 2009 4:33 pm
Just bought myself some bling proper oz wheels
Getting them powder coated to my preferred colour, but, does anyone know how too take out the bearing (without damaging them!) prior to me getting them coated
Cheers in anticipation,
Greg.
The lens guy, now the gixer mirror mount guy soon
bigun
- AP RS Legend
- Location: South Witham (nr Stamford Lincs) - exiled Geordie!
#2
Post
by bigun » Tue Jun 30, 2009 4:49 pm
Just buy new ones you tight git!
Seriously though, its difficult to get them out without absolute confidence you're not doing any damage. For the cost of new ones (go to simplybearings.co.uk for new bearings and seals) it'd be silly not to have that piece of mind. Give me a shout if you want a hand getting em out though.
Paul
Bigun
#3
Post
by Fausto » Tue Jun 30, 2009 4:49 pm
What are they made of?
If it's aluminium you could heat them up with a hot air gun and drift the old bearings out. Same procedure but in reverse for the new ones.
If they are made of magnesium/titanium/someotherpanium then I son't know but it may work.
minime
- Track Day Addict
#4
Post
by minime » Tue Jun 30, 2009 8:38 pm
why not tape the bearing up?
GregD-UK
#5
Post
by GregD-UK » Tue Jun 30, 2009 9:17 pm
Cheers Bigun, might take u up on that. They are made of steel and stainless I think! So no heaty uppy, otherwise, the housing will melt
You can't tape them up, they will be going into a heated oven to be powder-coated, not a done thing
Might buy a bearing puller, they aren't cheap thou...
- GP Racer
#6
Post
by Falcopops » Tue Jun 30, 2009 9:59 pm
I'd not be happy to reuse a set of bearings that had been pulled. Either drifting or pulling them has to transmit a huge pressure to the outer bearing surface through the bearings and inner bearing surface. I'd be concerned that they could be damaged, but not obvious to the eye. Considering the stressful job they do and the speeds involved, I'd go for new. Must be a fraction of the cost you've just laid out on the wheels.
#7
Post
by mangocrazy » Tue Jun 30, 2009 10:13 pm
Another vote for replacement. Once they've been drifted or pulled out, they're fit only for scrap IMHO. If you take the bearings into a local trade bearing stockist and ask them to match them up, you'll get them for cheap anyway. What ever you do, don't buy them off an Aprilia dealer!
And you can't leave them in, as the heat from the oven will totally knacker the grease in the races and the plastic seals they fit to keep the grease in.
GregD-UK
#8
Post
by GregD-UK » Tue Jun 30, 2009 10:16 pm
Point taken, I will put new one's in
Just want too be careful when I take them out
Will source a decent puller me thinks....
Chabby
- Clubman Racer
#9
Post
by Chabby » Tue Jun 30, 2009 10:23 pm
you'll have to 'drift' them out using a small enough diameter bar to fit through the spacer in the wheel centre.
#10
Post
by D-Rider » Tue Jun 30, 2009 10:39 pm
Drifting the first one out is nigh on impossible due to the design of the internal spacer tube in the hub - you just can't get anything through it and on to the bearing to drift it out.
I guess a puller will do the job - I didn't have one so I cut the bearing up with a dremel.
Once the first one is out, drifting the second one is easy.
redfalco
- Despatch Rider
#11
Post
by redfalco » Wed Jul 01, 2009 2:42 pm
Try your nearest Aprilia dealers, I bought the new bearings at Biker near Romsey and they removed the old ones free of charge.
GregD-UK
#12
Post
by GregD-UK » Wed Jul 01, 2009 9:18 pm
My local aprilia dealer doing something for free
Never in a month of sundays will M+S in ncle do sweet frig all for free!
simplybearing.co.uk is place for bearings people
Got the bearings out without any damage
The wheels, mille swingarm, and rear wheel hub are now getting a shiney new powder coating put on
The wallet is getting emptier by the day not month!!
