On a standard Falco, where are the throttle cables routed ?
cheers steve
Throttle cables ??????
- Track Day Addict
- Falcopops
- GP Racer
Nearly, and I'm prepared to be corrected, IIRC they run from the throttle, behind the right fork leg, in front of the head stock then between the frame and tank.sthomson1 wrote:Ive got my cables running in front of the forks around the headstock, between the tank and frame to the throttle bodies .... is this correct ?
It doesn't look right !!!!
