Knackered oil plug
Kenif
Knackered oil plug
#1 Post by Kenif » Wed Sep 19, 2007 12:44 pm
Well, after avoiding doing my own oil changes on the Falco for a couple of years for fear of overtightening the sump plug, I've finally got round to doing it. :smt001
Got myself a torque wrench to be safe. :smt004
First, loosening, turn of the wrench :smt041
nasty noise :smt120
put bolt down on strategically placed kitchen roll :smt078
notice strange silver residue and threads :smt086
Drain oil (both plugs)
Re-insert bottom bolt and turn to correct torque :smt109
Except, no torque, no resistance, in short, no fucking thread :smt093
Only thing I can imagine is that when it was last (1st) serviced, they must have overtightened to the point where it was stripped down to a fine grain but not far enough to drop back out again.
So, good news is, it didn't vibrate out at 140mph on the Autobahn :smt023
Bad news is, need to re-tap the hole :smt074
So, apart from generally sharing the misery, does anyone know what size bolt/thread Aprilia go with for the lower oil drain plug?
#2 Post by Nooj » Wed Sep 19, 2007 1:27 pm
No idea about the size, but when you do find out, tap the thread out and put an appropriately sized Helicoil in, that should stop it happening again.
Kenif
Coil
#3 Post by Kenif » Wed Sep 19, 2007 2:30 pm
Hi Nooj
First time I've ever seen this, looks cool. Do you know if you can use the insert without the tool? I know that sounds dirty but hey... :smt002
Katie Did
#4 Post by Nooj » Wed Sep 19, 2007 7:56 pm
Nope, you'll need the tool as well. Once you've done it you could always sell it on. Probably to another Aprilia owner :smt003
#5 Post by Falcopops » Wed Sep 19, 2007 11:34 pm
I did the same a while back and got it helicoiled back in. A while later managed to do the same with the helicoil :smt013
Took it to my local engineering shop and they tapped in a copper insert instead.
Not changed the oil since then so fingers crossed.
Kenif
coil
#6 Post by Kenif » Thu Sep 20, 2007 7:34 am
So, might be easier to just re-tap the thread, bung half a tube of ThreadLock in with it and make sure I take to the garage next time then? :smt009
Katie Did
#7 Post by Falcopops » Thu Sep 20, 2007 7:42 am
Prolly not, you'll get a loose fit.
I've always heard good reports about Helicoil. I just think that mechanic that did mine did it badly. I have my suspicions that the 1st time I stripped it it had been tightened to the point of stripping at the service. The same as you it seemed to strip as I took it out, not putting it in.
Granted the second time it was all my own doing, but I didn't have the washer on the bolt and I think it was this that caused it to pull the helicoil out.
Go with the Helicoil, if it doesn't work you can still make it good again, I did.
Thumper
#8 Post by Thumper » Thu Sep 20, 2007 12:31 pm
Hi Kenif I'm pretty sure the standard flange bolt is a M8x16, should be enough meat to go up one size and drill and re tap the oil tank to suit without a helicoil but the choice is yours mate.
Always expect the unexpected
#9 Post by fastasfcuk » Thu Sep 20, 2007 8:53 pm
if the helicoil's done properly you wont have another problem.
Kenif
Taps
#10 Post by Kenif » Sat Sep 22, 2007 4:59 pm
OK, have re-tapped up to M10 but it still doesn't feel right. Two choices:
Helicoil
Replace Oil tank
Advantage to choice 2, less chance of bunging another £50 down the drain as I mange to bugger up the Helicoil :smt009
So, before I go coil shopping, does anyone have a spare oil tank??
Katie Did
Kenif
Update
#11 Post by Kenif » Tue Oct 02, 2007 12:47 pm
Just in case anyone's still awake, found an engineering place to fit a Time-Sert (harder version of helicoil apparently) for £20.
Then, just to make sure it never happens again, I managed to find a complete set (M5, M6, M8, M10) of brand new Recoil insertion tools on Ebay for £50!
In case anyone lives in this region, Allbike Engineering in Greenwich were the chaps who dug me out of the badly stripped hole :smt004 They also do shock/fork servicing/rebuilds
http://www.allbikeengineering.co.uk/
Katie Did
#12 Post by Samray » Tue Oct 02, 2007 12:50 pm
Glad you got sorted. :smt001
If that's a recommendation it might be worth putting a link here. :smt002 https://www.ridersite.com/viewtopic.php?t=248
