I have sourced a bar and I'm going about moving the bars above the top yoke.
Can anyone tell me the thread on the master cylinder for a double banjo bolt? I need one to replace the hoses.
Thanks.
Banjo Bolts
Re: Banjo Bolts
Pretty sure it's M10 x 1.0 (that's the Brembo standard), Japanese bikes tend to be M10 x 1.25.
Re: Banjo Bolts
Re: Banjo Bolts
Bars are moved. Clutch hose is a little tight at full lock. I'll look at that tomorrow. I also had to make some lock stops to stop the bars fouling the tank. I have an even worse turning circle now
Re: Banjo Bolts
Good stuff! Now we need proof in the form of pictures...
