Will be coming to Blinkys meet on the Futura as the Falco seems to have a hot running issue, temp. climbs very quickly and runs about 10 deg. higher than usual.
I suspect a faulty thermostat, I guess jammed closed, so if anyone has a spare they could bring to the party I can borrow it for fitting & testing it would be much appreciated.
Obviously once tested it if fault is confirmed I will either supply funds or if not return to its rightful owner.
Thanks,
Keef
Thermostat
Thermostat
- blinkey501
Re: Thermostat
I have oneold git wrote:Will be coming to Blinkys meet on the Futura as the Falco seems to have a hot running issue, temp. climbs very quickly and runs about 10 deg. higher than usual.
Thanks,
Keef
Re: Thermostat
Make sure you pack it along with the kitchen sink thenblinkey501 wrote:I have oneold git wrote:Will be coming to Blinkys meet on the Futura as the Falco seems to have a hot running issue, temp. climbs very quickly and runs about 10 deg. higher than usual.
Thanks,
Keef
c u 2mora
