Re-augmented my cans again, mid-section back to normal and the TwoBrothers M2 Stubby Carbon Cans on the end! Had it re-dyno'd and there was a stutter around 1,000-1,500 revs. No amount of adjusting the map eradicated the problem
The guy (Simon) suggested maybe at low pressure, there could be a problem with my injectors. He has a sonic bath and injector checking contraption in his workshop. So, I was going to get a spare set of injectors and get him to clean and check there flow, spray, atomisation etc. Chuck them in and see if the stutter is eradicated
And then get the old one's also cleaned out and checked... For spares.
Anyone else had a stutter, apart from effects after 12 pints of scrumpy
