After changing the fluid a couple of months ago and finally getting the system working I noticed a few traces of white dried powder on the clutch case cover, I then redid everything and checked for leaks, I now don't have any but the temperature seems to climb form 76 to 80 odd really quickly and then comes down again when I get going.
Basically am I over thinking it and this is what the bike does or am I short of fluid in the reservoir which I will check again tonight.
One thing do you check the fluid on the level i.e. Abba stand or side stand.
As ever any thoughts would be appreciated
cooling system
cooling system
Speed Blue SL 1000 Falco
- randomsquid
- Wear the Fox Hat
Re: cooling system
On mine 76 is the temp it sits at in clean air (not trying to get past a milk wagon) at a reasonable open road speed, say 50 and up. I've had it slightly lower by forcing a metric fuckload of air in the front, on private land, obviously. Mine also happily wanders upwards if going slowly or traipsing through cities. Yours sounds completely normal to me.Tonyunn wrote:the temperature seems to climb form 76 to 80 odd really quickly and then comes down again when I get going
Mine is likewise, temp rises very quickly when dawdling amongst the sheep, clean air space it will stay 76/77, when the rads get some extreme ventilation I see 74.
As long as the fans kick it at around 99 don't worry.
Standard setting for the temp switch is fans ON at 98/99 and OFF at 95
- TwinkietheKid
- Despatch Rider
