Stuck open throttle at 130MPH
dazyguk
#1 Post by dazyguk » Sun Mar 23, 2014 8:57 pm
Just had the fright of my life. Throttle stuck open in top gear while already doing 130mph!! Had to pull up sharpish, clutch in engine off. Not quite sure what happened, twisted the throttle a few times seemed fine, started her up again stuck at max revs, turned off gave a few more twists then ok after a second start. Didnt feel a change in throttle feel.
I'm going to assume cable and/or spring. Anything else i should be looking for? Has it happened to anyone else?
Getting a bit of clutch slip too now at higher revs, barnett the answer?
#2 Post by fatboy » Sun Mar 23, 2014 9:27 pm
Glad you made it to a standstill from that speed (when you were NOT on the highway but on an un used airfeild near you, makes sense if you see what I mean)
I have similar clutch problems, works ok till you smash it open then SLIP bigtime
DONT buy EBC frictions, they dont bloody fit, stack height of plates too high.
Check all linkages and cable routing for snagging.
I use white PTFE grease on on fiddly bits, oil based lubes can destroy cables if they have a nylon inner liner between cable and outer
dazyguk
#3 Post by dazyguk » Sun Mar 23, 2014 9:30 pm
fatboy wrote:Glad you made it to a standstill from that speed (when you were NOT on the highway but on an un used airfeild near you, makes sense if you see what I mean)
Thanks for the advice, i'll be checking her over next weekend for sure. How can EBC sell their clutch plates if they don't fit? Shocking!
#4 Post by D-Rider » Sun Mar 23, 2014 10:11 pm
For the throttle "sticking" - It's unlikely to be the cable sticking unless the closing cable has snapped too - normally the butterflies would be pulled shut.
I have heard of one or two instances where the screws holding the butterflies onto their shafts have come loose and that has let them stay open enough to give problems. If that is the case, make sure you loctite them in place.
Of course, check there are no physical obstructions dropping in the TBs that might hold the butterflies open.
dazyguk
#5 Post by dazyguk » Sun Mar 23, 2014 10:14 pm
Yeah thanks for that, first things first need to clean my Y fronts :smt009
#6 Post by D-Rider » Sun Mar 23, 2014 10:34 pm
dazyguk wrote:Yeah thanks for that, first things first need to clean my Y fronts :smt009
Can't have been that bad if all they need is a clean!
I'd have expected that they'd probably been condemned to the incinerator after that .........
