Forza chip arrived today
zoidberg
#16 Post by zoidberg » Mon Oct 07, 2013 6:43 pm
The SL chip should have a daughter board. At least the one I have does.
zoidberg
#17 Post by zoidberg » Mon Oct 07, 2013 7:11 pm
Aladinsaneuk wrote:have a look at some of paddyz1's posts - he made his own evo type air kit
all you need is a dremel , some balls and some door sealant....
and no, I am not joking :0
I'm pretty sure that paddy made a Renegade style kit - not an evo one.
Plenty of info on how to make an evo-style one on AF1 BTW
My account still hasn't been activated there :smt017
#18 Post by Viking » Tue Oct 08, 2013 12:16 am
Aladinsaneuk wrote:I have never seen a genuine SL chip - but iirc they were on a daughter board?
the SL chip I have is fitted to a daughter-board.
#19 Post by fatboy » Tue Oct 08, 2013 5:48 pm
This little fella is fitted directly into the eprom socket. Im guessing the daughter board hosts ancillary components to the eprom ?
I mentioned the odd setting of the trim screws,could this be related to a 'missing 'daughter board ? Along with the everything or nothing low speed running ect
#20 Post by Aladinsaneuk » Tue Oct 08, 2013 5:52 pm
I think we need a photo
The daughter board enabled the ecu to be fitted iirc
#21 Post by fatboy » Tue Oct 08, 2013 6:24 pm
Oops, remove the glue and the eprom sits on a black board which sits on the white eprom socket.......
A mother and daughter combination ? :smt005
#22 Post by Aladinsaneuk » Tue Oct 08, 2013 6:27 pm
Perhaps one of the other SL chip owners has an image they can share?
zoidberg
#23 Post by zoidberg » Tue Oct 08, 2013 6:49 pm
#24 Post by Aladinsaneuk » Tue Oct 08, 2013 6:53 pm
Look similar fatboy?
#25 Post by D-Rider » Tue Oct 08, 2013 7:16 pm
fatboy wrote:This little fella is fitted directly into the eprom socket. Im guessing the daughter board hosts ancillary components to the eprom ?
The daughter board primarily connects the appropriate pins on the chip to those on the socket.
The chip has a different pin-out to the standard chip.
#26 Post by fatboy » Wed Oct 09, 2013 6:00 pm
Alad, that's the one ! Thanks Zoid for the pic.
I will have another play with this one, set the trim screws, check pins for crud and see if this sorts starting/low speed issues, areas where the Forza chip wins
