Suspension Settings
EEEP
Suspension Settings
#1 Post by EEEP » Fri May 04, 2007 7:57 pm
Probably a dumb question but here goes -
I have just put a yellow spring sachs mille shock onto my falco with the relevant linkages from the mille
Out a run this evening and I can feel every bump in the road, have checked the settings and they are as standard. I weigh about 16 1/2 stone.
How would I go about softening the ride a bit.
I am of to the Isle of Man on Thurs next and dont really want to have to put the blue sachs back on, any tips would be good cheers
EEEP
gazuk
Main bike: vfr 750ft
#2 Post by gazuk » Fri May 04, 2007 8:31 pm
Put the blue sachs back on, and to help you out I'll take the mille linkages of your hands. I'm helpfull that way :smt003
Will be interested in how you get on as I'm of similar weight to you, but don't have the mille linkages yet to go with my sachs yellow spring shock.
I assume you've set the sag? Many posts on here how to do it. Impossible for a 16stone guy to get it anywhere near the recommended settings when using the yellow spring shock with Falco linkages, so will be interested to see if you can with th mille ones.
sabestian
#3 Post by sabestian » Fri May 04, 2007 8:49 pm
No answer here but I weigh 13-14 stone kitted and I'm putting mine on tomorrow! Just need a baseline.
sabestian
#4 Post by sabestian » Sat May 05, 2007 8:51 pm
The bike feels like a bean-bag with standard Mille settings. But it handled well... I just softened everything and it feels 'normal' again. Lotsa playing before me. :smt020
Falco9
Re: Suspension Settings
#5 Post by Falco9 » Sun May 06, 2007 1:22 pm
EEEP wrote:Probably a dumb question but here goes -
EEEP
You now have sports bike suspension, not sports tourer, and yes it is a lot firmer and will kick you out of the saddle occasionally, I'm a tad heavier than you and it used to kick me out when using the Ohlins and the new T does the same.
It's the price you pay I'm afraid, a good suspension set-up is always going to be a compromise especially on the road but personally the firmer ride is a price worth paying for when you want to push on a bit
F9 :smt006
Thumper
#6 Post by Thumper » Sun May 06, 2007 2:14 pm
WEEP wrote:Probably a dumb question but here goes -
EEEP
I'm surprised you find it hard as you are on the heavy side as am I. What is the rider sag? and are you sure you don't have to much hydraulic braking dialed in? the 01 RSV shock should have around 12-14 clicks from fully closed for road use and around 20 clicks for the extended shock absorber, metal ring, but this changed on some models.
Always expect the unexpected
EEEP
#7 Post by EEEP » Sun May 06, 2007 4:31 pm
Thanks for all the advice/thoughts I have checked that it is at standard settings and it is. How would i soften it a bit would i go anticlockwise with the top and bottom adjusters and add a couple of mm to the spring length?
EEEP
Falco9
#8 Post by Falco9 » Sun May 06, 2007 4:39 pm
The only way to get a "softer" ride is back off both your rebound & compression damping. Backing off the spring will just lower you pre-load, it will make a bit of a difference but will probably upset your set-up and ruin your sag settings
F9 :smt006
