Fuel Filter
- blinkey501
I could biteAladinsaneuk wrote:The original falcos had larger intake snorkels.....
And yes, convincingly lapped by Keef - who lapped everyone bar the two chaps in white power ranger suits and Jay "what corner - oh that corner...excuse me while lie down".....
And pete you did have a disadvantage being on the back of an RAC truck so i will give you that one
- blinkey501
I always remove the banjo bolt from the throttle body end if removing the tank, and thread it back between the T/B'sfatboy wrote:
If you are going to do the filter,have a mate give you a hand to lift the tank,the banjo bolt on the return is a twat to undo/replace.
Also i don't remove the pivot pin under the seat that holds the tank,but the 4 bolts that hold the bracket that bolt it down to the sub frame.
I find this makes the tank removal relitively easy
I agree - much better way to do it. But installing a QD fitting on the flow line to the injectors at a suitable point would be the icing on the cake...blinkey501 wrote:Also i don't remove the pivot pin under the seat that holds the tank,but the 4 bolts that hold the bracket that bolt it down to the sub frame.
- flatlander
- Eprom Test Pilot (Stig)
Kwackerz wrote:
I did? I cant see it! ..and i'm on a ladder looking at my my phone?
