Memory foam and electric blanket?
Posted: Thu Dec 15, 2011 3:06 pm
by BikerGran
I've bought a memory foam mattress topper which is great for my arthritic hips - but now I'm puzzled about how to use my electric underblanket! Seems to me if I put it on top of the memory foam it'll negate the softness, but what will happen if I use it underneath? Anyone come across this problem?
Posted: Thu Dec 15, 2011 4:11 pm
don't use both together
i would use the electric blanket to warm the bed before you get in
Posted: Thu Dec 15, 2011 4:15 pm
Aladinsaneuk wrote:don't use both together
...... says the chap with the methane duvet .....
Posted: Thu Dec 15, 2011 4:23 pm
am only going by the advice I received from an older member
and btw, many thanks for your advice - my residents were really grateful that some one of more senior years took the time to share stuff
Posted: Thu Dec 15, 2011 5:21 pm
by snapdragon
nod nod :smt001
Posted: Thu Dec 15, 2011 6:23 pm
by BikerGran
What I'm concerned about is that having spent money on the mattress topper, if I then put the leccy blanket on top of it, it will partially negate the softness.
Presumably it does have to go on top?
Posted: Thu Dec 15, 2011 6:26 pm
It is perfectly safe to continue using you electric blanket, if you wish. Memory Foam is temperature sensitive and softens from your body’s temperature, the heat from an electric blanket will soften it further. You may find that too much excess heat will not allow your mattress or topper to support you correctly. Use only for short periods of time prior to bedtime and never use one whilst in bed.
Sounds right to me.
Posted: Thu Dec 15, 2011 10:11 pm
by BikerGran
Cheers all!
